MEVI hp gains
Old Apr 23, 2003 | 01:26 PM
mayhemI30's Avatar
"I'm running with scissors!"
MEVI hp gains
i know people say MEVI helps top end, but that is all i really hear about it. how much hp does it actually gain? or does it just take hp from one point of the powerband and move it to another. and is it compatable w/n20
Old Apr 23, 2003 | 01:50 PM
Nismo's Avatar
http://www.vanillaice.com/webmasters/hype/mrc/mevi.htm dynos at the bottom.
Old Apr 23, 2003 | 02:27 PM
xHypex's Avatar
Re: MEVI hp gains
It essentially loses some hp in the midrange, and adds quite a bit at the top end. To understand the hp gain you really have to understand the hp equation: Horsepower = (Torque*Rpm)/5252
Thus the more torque you gain at high rpms, the more horsepower you gain.
You will gain a lot more power from nitrous than a VI, but the VI will always be there. You'll gain even more with nitrous and a VI
-hype
Old Apr 23, 2003 | 02:39 PM
iansw's Avatar
www.cyberhub.net/manifold
Disclaimer:
This is, however, with the MEVI turned off and with it turned on - not the USIM and the VI.
Old Apr 23, 2003 | 02:56 PM
n2o_matt's Avatar
Disclaimer:
this shows a top hp of 155 with VI.
Nissan says that the maxima is 190 stock
is this at the flywheel?
srry if this is just showing my ignorance
Old Apr 23, 2003 | 02:59 PM
xHypex's Avatar
The rated 190hp is at the flywheel. All dynos you see listed are in wheel hp.
-hype
iansw's Avatar
Wheel Dynos measure only at the wheel. This is when I had an intake, and that's it, besides the MEVI.
My Dyno now is:
http://www.cyberhub.net/dyno/Dyno101902.jpg
Old Apr 23, 2003 | 03:01 PM
meccanoble's Avatar
Sports Button FTW
Re: Re: MEVI hp gains
-hype
and torque is like acceleration aka putting your back on your seat right
Old Apr 23, 2003 | 03:02 PM
iansw's Avatar
Re: Re: Re: MEVI hp gains
yeah - it's especially bad-azz if you have a Twin Turbo.
Old Apr 23, 2003 | 06:40 PM
mayhemI30's Avatar
ok w/n20
i'm an auto so will it be as noticeable? and what should i set it to open at? should i usse at the same time as the nitrous?
Old Apr 23, 2003 | 06:52 PM
bb0ys's Avatar
ugh
I always think a MEVI would be a great add on because so much power is lost above 5500...but then I look at the actual numbers and it seems so not worth the $ unless you can mod your rev limiter (95-96 ecu only) or are boosted (way more $). The VI alone just doesn't seem worth it...But I'm sure other people feel different. Just voicing my opinion =)
Old Apr 23, 2003 | 07:12 PM
plurco's Avatar
Re: Re: Re: Re: MEVI hp gains
poor kid. you know the bad thing is, it must have been 6 months ago when his TT post got pinned. But in his defense you "can" do a twin turbo on a max, but why?
Old Apr 23, 2003 | 07:57 PM
iansw's Avatar
Re: ok w/n20
I was the first NA Maxima with the MEVI back in the day.
I know I'm biased, but I felt the power increase immediately, and I never regretted it for a second. Makes the drivability of the car (especially on the freeway) 100x better.
After 28 Dyno runs, I have found that 5000 RPM is the best switchover point. SOme people disagree and use 5200RPM....test aorund and see what works for you.
As for N20, I don't know - don't have it.
IanS
Old Apr 24, 2003 | 07:16 AM
mayhemI30's Avatar
Re: MEVI hp gains
and is it compatable w/n20?
Old Apr 24, 2003 | 07:20 AM
xHypex's Avatar
-hype
litch
123
Jan 4, 2024 07:01 PM
BkGreen97
Apr 2, 2016 05:47 AM
lrb6805
Sep 30, 2015 08:12 AM
Marc2theMax
Sep 28, 2015 08:13 AM
Sep 27, 2015 08:37 AM
