my car is throwing 0304 code, please help
Old Apr 23, 2003 | 04:56 PM
Tuna's Avatar
well, i guess this is why i've been gettin crappy gas mileage.. my question is this is the only code that pops up and after i reset it i get the 0505 code again.. but a day later the knock sensor code pops up again.. i got a 97 SE w/ 64k miles on it.. could it be the knock sensor itself or could it be something else..?? my tranny shifts kinda ruff when it's cold and when it's warm it still jerks a little from 1st to 2nd.. could the knock sensor be tripped up by this or could it be something else..?? i know that when i first bought the car i was gettin great mileage but since about 6 months ago it's been crappy.. i dont know whats goin on.. someone help me please..
thanx in advance..
oh yea.. i just did the basic 60k tune up too (spark plugs(NGK Plats), pcv(oem), throttle body cleaning, oil change, tranny flush, power steering flush, front brakes, bled front brake lines)
Old Apr 23, 2003 | 05:05 PM
PAREDLINE's Avatar
0304 in my book is cylinder #4 misfire.
Ohhhh 0304 on 'check engine' is Knock Sensor. So thats the problem.
Good work. You can change it and it'll go away. Everything will be peachy
Old Apr 23, 2003 | 05:08 PM
Tuna's Avatar
Old Apr 23, 2003 | 05:21 PM
TonyGotSkilz's Avatar
0304 is knock sensor and it sucks, its hard as a ***** to get to but definitely something you can fix on your own especially if you have an intake (cause theres less piping to take out). Its worth it too you'll notice performance gains with a good knock sensor vs a damaged one.
Old Apr 23, 2003 | 05:22 PM
Romeo's Avatar
0304 is your knock sensor. the knock sensor error can be a bunch of different things. i'd reset it again and see if it comes back on. if you have a haynes or chilton's manual, use it to check if the sensor is good or bad before you replace it.
Old Apr 23, 2003 | 05:40 PM
Hunter11's Avatar
Is there any way to check to see if the sensor is bad without actually replacing it?
Old Apr 23, 2003 | 08:12 PM
Tuna's Avatar
i reset it yesterday and got the 0505 code after doin so, but today i check it again and i get the same 0304 knock sensor code.. is the knock sensor only tripped by a knock in the engine or could it be tripped by the rough shifting from 1st to 2nd.?? also, do they normally go bad at around 65-70k miles.?? how could i check if the knock sensor has gone bad, cuz i dont wanna spend 100 some odd dollars replacing something that's not broken.. one more thing, what would happen if i just disconnect it.??
thanx..
Old Apr 23, 2003 | 08:18 PM
sandman1098's Avatar
If you disconnected it, you would probably still get the 0304 Knock Sensor code...The sensor has to be hooke up and working properly if you want to get rid of the CEL
Old Apr 24, 2003 | 04:08 AM
Tuna's Avatar
ok.. so is there any way to check if my knock sensor is bad.?? how many miles does it take before they usually go bad.??
Old Apr 24, 2003 | 05:49 AM
Lime's Avatar
0304 repeatedly is a Knock Sensor malfunction. This is a very common error in 4th generation maximas. Buy the part ($$), and use these instructions (make sure you follow them exactly) to replace the part.
Old Apr 24, 2003 | 06:37 AM
gtr_rider's Avatar
192.168.1.1
http://forums.maxima.org/showthread....highlight=0303
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
doobadoo
Aug 15, 2015 06:43 PM
jholley
Aug 11, 2015 09:38 AM
maxima297
Aug 3, 2015 12:50 PM
