How to read ohm tester to check knock sensor
Can someone tell me how to read my ohm reader? I got a cheap one from Advance Auto Parts but I am not really sure how to read it. I am wanting to test my knock sensor. In the haynes manual it says to test the KS at least 10 M-ohms. What is that?
Can the tester I have do this? On my tester,on the ohm section,the settings say(clockwise)200,2000,20k,200k,2000k. Can I test my KS with any of these settings?
Unplug the K/S wiring harness. (leave the K/S installed)
Set your DMM to measure 0-20 VOLTS.
Put the positive lead on the feedback wire terminal coming from the sensor & put the black lead on a good ground.
A properly functioning Knock Sensor should be putting out 2-3 volts from the "hot" wire (I think it was white or green) with the engine running.
If the reading is significantly higher or lower than 2-3v, your knock sensor may need to be replaced.
PS: Ohms are a measure of resistance in an electrical circuit. A check for voltage in this case may be a better bet to determine if your K/S is ok.
kjlouis
Nov 24, 2018 06:09 AM
jskirwin
Jun 8, 2016 08:49 AM
maxinout93
Aug 20, 2015 02:17 AM
doobadoo
Aug 15, 2015 06:43 PM
