Fuel pump shot?
Old Apr 24, 2003 | 04:33 PM
|\|issan|\/|ax's Avatar
Fuel pump shot?
In the Haynes manual, to relieve the fuel pressure, I believe one of the first things you do is remove the fuse for the fuel pump and start the car. It is supposed to die after a few seconds. HA! My doesn't. It continues to run for about 5 minutes before finally giving up.
So my questions are:
1. is the fuel pump shot?
2. what compenents are between the fuel pump and fuel filter other than the fuel regulator?
3. what is wrong with my car?
Old Apr 24, 2003 | 05:30 PM
dwapenyi's Avatar
Your car's fine. I bet when you did this, the car was very warm (been running for a while befroe you stopped to change the filter,) and at a low idle. Therefore, it didn't need much feul to stay alive while the pressure, and hence feul, was relieved inside the feul lines. Same thing happened to me but it was like 3 minutes before the car died.
DW
Old Apr 25, 2003 | 03:26 PM
Re: Fuel pump shot?
I just realized that there is a difference between a fuse and a relay . Aren't you supposed to remove the relay?
Old Apr 25, 2003 | 05:13 PM
xHypex's Avatar
Pulling the fuel pump fuse kills my car pretty quickly I've done it several times for replacing fuel filters, installing a fuel pressure gauge, and doing a compression test.
-hype
jmlee44
Oct 2, 2022 02:13 PM
Miket2006
Mar 1, 2021 03:55 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
