strut bearings for cheap?
Old Apr 25, 2003 | 08:05 AM
NotNew!!NewSN!!'s Avatar
strut bearings are insanely expsensive for something so small and not even that impressive. If anyone knows anywhere cheap to get strut bearings let me know. They are the little things that are on top of the front stronts to let it rotate when u turn the steering wheel.
Old Apr 25, 2003 | 08:13 AM
mzmtg's Avatar
Minister of Silly Walks
If the bearings arent physically deformed or damaged, they can be "repacked".
Just carefully seperate the 3 pieces that comprise the bearing and lubricate them all with a healthy dose of waterproof axle grease.
Old Apr 25, 2003 | 08:17 AM
njmaxseltd's Avatar
It's a $20 part that the weight of your car sits on. It holds the spring perch in place against the upper strut mount, plus it has to rotate freely under that load.
For the job it does, you think thats expensive?
Old Apr 25, 2003 | 09:17 AM
bgod's Avatar
i wouldn't bother to even try to repack the bearings or relube them. to do all that work to find out you still need new bearings would be just useless.
i'm about to change my bearings in a week or two. the driver side is squeeking worse and worse everyday.
Old Apr 25, 2003 | 09:39 AM
Whitemax's Avatar
Disco Biscuit
Do yu have to completely remove the strut to replace it, or can you just undo the top, and raise the front up with a jack to drop the assembly?
Old Apr 25, 2003 | 10:30 AM
njmaxseltd's Avatar
Remove the strut, compress the spring and take off the upper mount to get at the bearing.
Old Apr 25, 2003 | 10:45 AM
The physical property of something opposed to what it does has nothing to do with price. Price deals with materials made to use the item. The only time application raises the price of something is when the maker knows the buyer will pay it, and thats when i get pi$$ed. Its a simple simple bearing design. Not a 20 dollar bearing.
Old Apr 25, 2003 | 10:58 AM
Brockster's Avatar
I've been reading that strut monuts are about $35 each. Who has them for $20???
Old Apr 25, 2003 | 11:04 AM
njmaxseltd's Avatar
Umm yea, OK. Run that by an engineer.
Old Apr 25, 2003 | 11:25 AM
I guess since I'm an engineer in training, and intern at one of GM's concept car design and development suppliers, I will. Wait my last internship here I had to do research on bearings and ordering them for something on the H2 aftermarket. Low and behold, the bearing I ended up using is one of the most complex and intricate kind for loads of up to 10,000 pounds that is so tightly pressure fitted that the bore is actually the same size of what is going through. How much did it cost? 18.50. How much were types that nissan uses? 3 bucks. Let's not argue over the internet here, we're all nissan love, but I think when you look at the big picture here, you can agree that 35 bucks for that is overpriced. Yes its an important piece, but tha doesnt mean it should be turned into a monopoly.
Old Apr 25, 2003 | 12:24 PM
bgod's Avatar
you can make the same arguement for almost any product made today. the turnaround equals profits. low overhead and mark-up at retail.
what exactly is your case here. yes, the items of course are marked up. in reality, how much do you think it costs to make products such as spring, struts, tires, etc. absolutely nothing compared to the profit. people are paying close to $100 per tire when it probably costs $10 to make after design costs.
reality is, if you need it you'll pay the $35 or $20. if you want to repack the bearings then that's your perogative.
Old Apr 25, 2003 | 12:31 PM
bgod's Avatar
Old Apr 25, 2003 | 01:53 PM
well the point got strayed from real easy. Anyone know where to get the strut bearings cheaper then from the dealer?
Old Apr 25, 2003 | 10:22 PM
Brockster's Avatar
Old Apr 25, 2003 | 11:49 PM
Bgohan's Avatar
Could YOU build that bearing for $20.00?
Or build it in 2 hours (2 hours @$10.00 per hour).
It is all relative.
Old Apr 26, 2003 | 08:06 AM
Vyrus's Avatar
Courtey sells them for about $26.50/each plus shipping.
-Cyrus
Old Apr 26, 2003 | 12:08 PM
klymkow's Avatar
If you want OEM, go to www.nissanparts.cc:
54325-5V000 Bearing-strut
list $31.95
sell $24.35
shipping $7.95
This new number does cost more than the old part 54325-31U01, which was $18 list.
Oh well, new and improved!
Tim
litch
123
Jan 4, 2024 07:01 PM
maxima-junky
Oct 7, 2015 06:13 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Andy29
Sep 29, 2015 05:32 AM
