Electrical troubles
Old Apr 26, 2003 | 07:21 PM
sandman1098's Avatar
Electrical troubles
Is there a way for a battery to lose most of its charge in a short period of time? Al the accessories in the car work fine, and I dont think there are any shorts..... My alternator seems to be working fine, and putting out enough current....
Any ideas on things for me to check for?
Old Apr 26, 2003 | 10:28 PM
imstuckherenow's Avatar
get a new alternator or get it checked out. was ur max in on the recall?
Old Apr 26, 2003 | 10:31 PM
95GreekMaxSE's Avatar
exactly wat sympoms are you having... how long ago did you get a new battery
Old Apr 26, 2003 | 11:05 PM
The battery is a Nissan battery...... Im assuming its the original one... I havent gotten the new battery yet..... I need to take the car to Autozone to get the Alternator checked (I dont have a Voltmeter).... I have a feature on my Radar detector that lets me see how many volts my electrical system is putting out, and its usually around 13.3 or 13.2.....but thats not a good diagnosis of the charging system though.. lol.....
Old Apr 27, 2003 | 09:11 AM
i would get a new battery, and highly reccomend one with 700 to 900 cold crank9ng amps..autzone has a deal..900 cold cranking and 1000 regular cranking for 80 bucks..duralst gold battery that i just got...i would recommend this and new blets,, then see how the car acts... If symptoms persit then get a new alternator right off the bat..
Old Apr 27, 2003 | 09:14 AM
kewl..... Another weird thing about my car is that the Check Engine light does not come on when I turn on the igntion, just before I crank the car..... Could that be related to my battery problems????
Old Apr 27, 2003 | 09:16 AM
it seems like your car is choking when it starts..i bet if you start the car without your seatbelt on.. listen to the seatbelt warning chime..listen to the way it beeps while starting..are the beeps consistent or choking along with the starting of the car????
Old Apr 27, 2003 | 09:21 AM
It chokes along with the starting of the car.....
Old Apr 27, 2003 | 09:23 AM
replace that battery and belts...ASAP
Old Apr 27, 2003 | 09:27 AM
KWheelzSB's Avatar
Don't rush to the solution without a diagnosis-
1) Loosen & retighten the charging system grounds & connections, including those to the alternator.
2) Clean your battery terminals & retighten for a fresh connection.
3) Apply dielectric grease to the battery terminals and other connections.
4) Check the water level in each battery cell - if it is low, add distilled water to the indicated fill level.
5) Check the condition of your individual battery cells using a hydrometer ($3-$5 at any auto parts store) Wear protective eyewear - battery acid is corrosive & can blind you/burn skin).
6) If neccessary, charge the battery overnight using a trickle charger to see if it will take/hold a full charge.
7) Using a digital multimeter, measure output from the alternator (just put the test leads on the + and - posts of the battery) with the car running and the throttle held at approximately 2,500rpm. If the alternator is ok, it should be putting out 13.25-14.00+ volts.
8) Also, be sure to check the condition and tension of your serpentine belt (the one that drives the alternator). Replace the belt or adjust the tension (using the tensioner adjustment nut on top of the tensioner pulley) if neccessary. Be careful not to overtighten, as this will lead to premature pulley bearing failure!
Those are the basics to start with. Hope this helps.
-K-
Old Apr 27, 2003 | 09:35 AM
true...but the battery is type old and needs replacing as it is..i mite not hold a chrge anymore and causing wear on the alternator..i had the same problem and the betls were cracked to teh point were it was spinning on the spine of the belts ready to snap..
Old Apr 27, 2003 | 09:39 AM
THanks guys.... I will do everything you guys have suggested today....
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
