maxspeed spring users look!
Old Apr 27, 2003 | 12:37 AM
Max Noob's Avatar
i have a set of maxspeeds under my bed with agx. gonna install soon.but wanna know bout the afterdrop with these springs. is the drop even?... i notice the max sits lower in back. i was planning on cutting half a coil off the front to even it up. also is camber in spec without a kit. ill still be on the stock sawblades. do these relatively soft springs do good to end the mushy handling of the max?thanks.. pics would be appreciated.. how many inch gap is betwwen tires and well now? thanks..later
Old Apr 27, 2003 | 08:30 AM
XXXL Cracker's Avatar
Re: maxspeed spring users look!
[QUOTE]
The drop on my car is completely even. It is always good to get an alignment after dropping it. You will not need a camber kit.
It will handle nicely with the AGX.... adjustability at your fingertips.
BTW: why didn't you ask these questions before buying the stocks and springs.....
Old Apr 27, 2003 | 09:51 AM
Anachronism's Avatar
The Maxspeeds drop the front more than the rear, enough that the car sits even or even looks sightly lower in the front. I love the 'raked' look of the slightly lower front but I decided to go with the H&Rs that have been around for a while and are proven. The H&Rs also drop the front more than the rear but not as much as the Maxspeeds. The car looks even or slightly higher in the front with H&Rs. They should handle better than stock.
Try this link to find pics of maxes with Maxspeeds - http://www.google.com/search?sourcei...n.com+Maxspeed
Do not cut spings
Old Apr 27, 2003 | 10:12 AM
cmoe211's Avatar
Hey Bro I have this exact setup max/agx,the drop is EVEN and the ride is smooth as hell.I love it!DON'T CUT SPRINGS!!!! d_warner has pics of the drop.Oh yeah and being able to adjust agx whenever you want so easily is Kewl!
Old Apr 27, 2003 | 12:12 PM
rbeyer's Avatar
I wish my drop ended up even! I don't think H&R's on all occasions drop the car even, and I'm not sure why. I have rear sag and I hate it. I had to put spacers in the rear to give mine the agressive look. Problem being the car doesn't looked droped as much. The springs are in right and checked over by JAY25. I think Iansw also has a problem with sag when others say they don't with his B&G's. What's up with this??? Good luck w/ the Maxspeeds....hope you get the same results everone is claiming and are sag free!
Old Apr 27, 2003 | 12:24 PM
NiNe7-Gxe's Avatar
drop is even to me...
i think its the way the fenders are that make the car look lower in the front than it is in the rear
Old Apr 27, 2003 | 01:42 PM
WHere did you find the spacers?
And a side note, before Dave B. busts in here... The car sits even stock, but since the front wheel well is cut higher the front appears to be higher and has more wheel well gap.
Old Apr 27, 2003 | 01:48 PM
rbeyer's Avatar
Regardless how it was cut...it looks saggy and that's no good. The spacer I got were from PepBoys...like $10 or something, but they have to be shaved down a little or they will lighlty rub your strut when you put them in.
Old Apr 27, 2003 | 02:04 PM
Max Noob's Avatar
thanks guys
seems like most people report an even drop.. i forgot to mention i have a 5 speed. tranny if lighter than auto. will that effect the evenness any?. thank again for all the replies.
Old May 1, 2003 | 02:50 PM
Max Noob's Avatar
when u guys say even drop.. do u mean te car is even or is the gap in the front and back is the same.. im lookin for a drop that makes the gaps even the same. if the car is tilted to the front a lil bit is ok with me. is the maxspeed drop even in respects to the wheel gap?
Old May 1, 2003 | 03:49 PM
Tri-lite's Avatar
I have a 5 spd. GXE. I have 4 finger gap in front and 3 in the back ...
but when you look at the car from the side it looks even. the ride is very smooth (sometimes to smooth for my likings) but with agx you should be happy!
good luck!
Old May 1, 2003 | 03:53 PM
Grey00lustre's Avatar
i have maxspeed/gr2 combo...my drop was almost even..u will notice the front slightly lower than rear...
Old May 1, 2003 | 10:33 PM
co_maxima98's Avatar
My Maxspeed's gave me a nice, even drop as well. The nice thing about 'em is that it makes the Max look like it should have looked from the factory... and it stiffened up my ride noticeably compared to my GXE suspension, but not too much. It still rides smooth.
Here's a few pics of my drop if you want to see what it looks like. You can see that it's a bit higher in the rear.
http://images.cardomain.com/member_i...74_42_full.jpg
Close-up front: http://images.cardomain.com/member_i...74_43_full.jpg
close-up rear: http://images.cardomain.com/member_i...74_44_full.jpg
(those pics are with my 17's, but I have pics with my stock 16" SE rims on my homepage if you wanna see what it looks like)
Old May 1, 2003 | 10:45 PM
Xmax's Avatar
Here checkout my cardomain page....I have Maxspeeds and a KYB AGX setup. My car sits fairly even. The front is 3 a finger gap and the rear are a 4 finger gap...its hard to tell untill you look very close. Almost forgot...I had my Maxspeeds on for more than a year now. And it hasn't given me any problems
my cardomain site
Old May 1, 2003 | 11:10 PM
Max Noob's Avatar
damn..that is still a pretty big gap..i was hoping for no more than liek a 2 finger.people wont even notice its dropped. oh well..
Old May 2, 2003 | 01:01 AM
masterB's Avatar
how is the maxspeed springs compare to stock SE springs???
my car is a SE. should i go with something stiffer??
Old May 2, 2003 | 01:53 AM
Max Noob's Avatar
they are supposedly comparebly to h&r.. like 15% stiffer than se suspension.. good for street and a mildly agressvie everyday driver..if your going autox or track..then these arnt for you. all depends on what u want..
Old May 2, 2003 | 04:48 AM
mrmaxima97's Avatar
I love the drop I got from that combo. Its not too much and not too little.
Ride is nice, except for the noises but I will get them fixed soon.
litch
123
Jan 4, 2024 07:01 PM
JonBlz
Oct 5, 2015 06:02 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
followthadollar
Sep 27, 2015 01:06 PM
