no one in my life as been able to answer this question
Old May 1, 2003 | 11:54 AM
delacruz_17's Avatar
why does the timing chain have to be at a certain spot on the sprockets.
I know that the sprockets must be at a certain spot with respects to the other sprockets, but why does the chains location matter?
Old May 1, 2003 | 12:00 PM
BigJuice's Avatar
Re: no one in my life as been able to answer this question
because I say so
Old May 1, 2003 | 03:53 PM
Sleeper ZZ's Avatar
My guess is to help the initial positionning of the chain, it would be easy to just slide one tooth (when the chain is not align with a gear tooth you go foward or back to drop in that could cause an incorrect timing if you did not have a mark to indicate a start or match point.
I guess engineer like marking these thing.
Old May 1, 2003 | 05:03 PM
Nismo's Avatar
maybe to indicate if the chain is jumping teeth or used as a start point to count ratios
Old May 1, 2003 | 10:41 PM
hummmmmm nismo that has gotten me thinking now
Old May 1, 2003 | 11:07 PM
Jeff92se's Avatar
I'm needing a caw
Ugh. Yes if you can somehow position the sprokets PERFECTLY then you can put the chain on anyway you want. But do you realize how hard and utterly impossible that would be? The chains have marks so once you put it on the crank w/ the bright link on the sproket marker, you can now align the other sprokets on the other bright links on the chain. Now you KNOW all the sprokets are in proper phase with each other.
What do I win?
Old May 1, 2003 | 11:40 PM
K Pazzo 6's Avatar
Originally posted by Jeff92se
What do I win?
Old May 2, 2003 | 07:56 AM
um jeff so the ONLY reason is that you will be able to know that the sprockets are correct. Makes a whole lot a sense, I was always told Nooooo!!! It must be put this way but i never understood why. I knew that the sprockets must be alligned and I see how the markers would be very helpfull if by any change the sprockets would move when u were putting on the chain. So i'm guessing the chain is all the same all around, ¿right?
Old May 2, 2003 | 08:29 AM
Jeff92se's Avatar
I'm needing a caw
Originally posted by K Pazzo 6
Old May 2, 2003 | 08:30 AM
Jeff92se's Avatar
I'm needing a caw
Same all around? It's a chain. Align the chain on the crank and then position the sprockets according to the chain links. Period. There's more than one chain also. I believe 3.
Old May 2, 2003 | 09:10 AM
luckee2bhere's Avatar
has anyone else noticed an abundance of noobs lately? ...good thing
9aj9
Apr 5, 2020 12:11 AM
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
