Do I Need A Fuse To Brighter My Corner Lights
Old May 1, 2003 | 05:51 PM
kamina's Avatar
DO I NEED TO INSTALL A NEW FUSE FOR THE CORNER LIGHTS BECAUSE I MADE THEM BRIGHTER?? AND WHAT NUMBER FUSE DO I NEED????? THANX
Old May 1, 2003 | 05:54 PM
imstuckherenow's Avatar
no u dont need a new fuse
Old May 1, 2003 | 05:55 PM
kamina's Avatar
SO MY BULB IS NOT GOING TO BLOW OUT CUZ I MADE THEM BRIGHTER????
Old May 1, 2003 | 05:57 PM
s0ber's Avatar
no there not going to blow..
take off caps or they will blow :P
ch13f's Avatar
NO!!! turn caps lock off... its extremely annoying. The bulb is made to handle the amount of power you are putting through it.
Old May 1, 2003 | 05:59 PM
kamina's Avatar
thanx.. everyone
Old May 1, 2003 | 06:25 PM
ch13f's Avatar
Old May 1, 2003 | 06:42 PM
DigitalTexan2u's Avatar
Whoa...some echo in here
Old May 1, 2003 | 07:22 PM
99maximagxe's Avatar
so for 97-99 do u cut the lower nub or the higher nub? theres some debate over that on the brighter corner thread.
Old May 1, 2003 | 07:27 PM
kamina's Avatar
ok guys i found out here is the deal
95-96 its the lower nub
97-99 its the higher nub
okzzz !!!!! thanx everyone
Old May 1, 2003 | 08:49 PM
wtf u talkin bout cuttin the nub? if u talkin bout the lights next to ur headlights u jus use a saughtering (sp) gun abd move the wire from one nub to the other!
Old May 1, 2003 | 09:39 PM
ivan25's Avatar
cutting?
what do you mean by cutting the nub?I read somewhere in here all you have to do to make them brighter was flip them upside down?Im pretty sure I read it in here or somewhere in the web..Anyways I havent done this yet so Im not sure if you just flip or cut?
Old May 1, 2003 | 10:02 PM
Bgohan's Avatar
Re: cutting?
But don't you have to stand on your head before flipping them upside down.
Some people have reported that their fuse HAS blown after switching bulb around to the 27W side. If it happens to you, you likely have a corroded or loose bulb/connnection somewhere in the circuit. Just use a 10 amp if other fuse blows. No harm will come to your harness from the slightly larger fuse. Long story.
But, if a 10 amp fuse blows, you've got a problem, somewhere. You'd better check all bulbs and sockets in circuit.
Cut or grind off the proper nub, bend in the top of the bulb socket slightly on missing nub side so bulb will be tight, install bulb. Done deal.
Removing lens can be difficult. It's in pretty tight. Spray around rubber seal on outside edge of lens with Armorall to make it slip out just a little easier.
Old May 1, 2003 | 10:40 PM
Stillnmax's Avatar
you guys said " NUB "
Old May 2, 2003 | 05:06 AM
callkiss's Avatar
No Fuse Will Be Needed For That Customization.
Jamie Bowen
Sep 6, 2015 09:59 PM
pktaske
Sep 4, 2015 08:40 AM
mikebla
Sep 3, 2015 05:37 PM
