installed H&R springs
Old May 2, 2003 | 11:36 AM
Cumalot's Avatar
Yes I decided to keep the H&R springs afterall. I had it the H&R springs installed today. The ride is pretty good. Mind you though, my front and rear AGXs are set a 1. Some people have said that too low of a setting would make the ride bouncy and ride like it's on blown struts. I didn't notice this at all. The ride isn't bouncy, it's definitely stiffer than the stock SE springs. However, it's not too stiff, just a bit stiffer than the SE springs. The front end is a bit higher than the rear end. I measured it: the front end is about a four finger gap and the rear end is about a 3 1/2 finger gap. I have small hands and bony fingers, so keep that in mind. Even though the front end is a bit higher than the rear, it doesn't bother me at all. Maybe I am getting old. It's definitely an improvement over stock that's for sure. Do you guys think I should stick with the 1f/1r setting of the AGXs? I'm not sure if I should bump up the setting on the AGXs, but I'm worry if I do, the ride will suffer(i.e. stiff). Overall, I'm quite pleased with the H&R springs and AGX struts combo. Another reason why I put the H&Rs on is because I'm going to some new rims soon. Soon I wait until I get an alignment before I put the new rims on? I asked this because I know I have to wait about 2 weeks for the springs to settle a bit before I go get an alignment. I don't want to put the new rims on and have an uneven wear so soon because it's not aligned yet.
Btw, the Eibachs are still for sale.
Old May 2, 2003 | 12:36 PM
drewm's Avatar
Re: installed H&R springs
Glad you finally found some springs you like.
Adjusting settings can't hurt, you might even find something you like better. I'd personally try something around a 2/5 to see how it feels. The back of a maxima generally needs a lot of dampening.
Something you might find useful:
Approximate values for the AGX settings vs OEM and GR2
http://drewm.dyndns.org/~drew/maxfaq...KybAgxSettings
The rims shouldn't be a factor in your alignment worries. If the stock rims have so much toe in, the aftermarket ones will be the same. Just wait a few weeks for it to settle and go get one done.
Old May 2, 2003 | 12:43 PM
GoldenGlory
im ridin on 3 front and 6 on rear.
i luv it.
spring take a while to settle in to its max drop.juss ride around with some real heavy people
Old May 2, 2003 | 12:51 PM
Cumalot's Avatar
Yeah, I think I'm going to play around with the AGX setting to see which I like. I think I'm going to try 2/4 and see how that rides.
Old May 2, 2003 | 01:15 PM
deezo's Avatar
You have the "Most times modded" car on the org.
Old May 2, 2003 | 04:01 PM
Cumalot's Avatar
Re: Re: installed H&R springs
Old May 2, 2003 | 04:52 PM
deezo's Avatar
Re: Re: Re: installed H&R springs
Old May 2, 2003 | 07:35 PM
piopremier's Avatar
based on that chart of stock to agx settings will you get more life out of the struts if you set the # higher?
Old May 2, 2003 | 09:05 PM
drewm's Avatar
I'd probably have to say yes, due to the higher dampening preventing the shock from bottoming out. That's the biggest killer of shocks. And if not that, a higher setting will cause the shock to travel less, leading to less o-ring, internal body and piston wear.
But also, in general, the lower and stiffer your springs are, the more your shocks will wear.
Old May 3, 2003 | 05:46 AM
Smithdogg1's Avatar
What kind of bodykit is that on your car?
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
Hdnseek
Sep 9, 2015 05:55 AM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
