Nyc Inspection Failed !!!!
Old May 2, 2003 | 04:23 PM
droc
ALRIGHT I NEED SOME HELP HERE I HAVE A 96 I30T YPIPE N CAT BACK AND STILLEN INTAKE
SO I GO FOR INSPECTION DRIVE A GOOD HOUR BEFORE I DROP THE CAR OFF THEY DO THERE TEST THING I COME BACK AND I FAIL FOR NOx the limit WAS 1.50GPM I TESTED 2.05 GPM THE REST OF THE READINGS ARE AS FOLLOWS HC .26GPM AND CO 5.80 GPM I
IF ANYONE COULD LEAD ME A DIRECTION TO FIX THE PROBLEM I WOULD APRECIATE IT
ALSO JUST GOT AN INJECTOR CLEANING 2DAYS AGO AND NEW PLUGS
Old May 2, 2003 | 05:41 PM
vipervadim's Avatar
I like Maximas
Re: Nyc Inspection Failed !!!!
that sux man.. i'm also in ny and i'd say warm up the car real nice before the inspection and don't let it cool
cats start to work only after they get to a certain temperature..
or an effective solution: you can put your stock y-pipe back on for inspection and then pass, and then put the aftermarket y-pipe right after, successfully fooling the system. it's a bit of work but it beats paying $35 for each failed inspection.
-Vadim
Old May 2, 2003 | 06:03 PM
njmaxseltd's Avatar
Clean your throttle body if it wasn't included in your injector cleaning.
See www.motorvate.ca for instructions.
Old May 2, 2003 | 06:10 PM
NickStam's Avatar
and don't use caps. Ny inspction doesn't like that either
Old May 2, 2003 | 06:15 PM
luckee2bhere's Avatar
Old May 2, 2003 | 10:43 PM
Nismo87SE's Avatar
Check and clean your EGR system. If you pass everything else but you are high in NOx that means there is an issue with the EGR system.
Old May 2, 2003 | 10:57 PM
Lonely Driver's Avatar
Use the higher octane gas if you aren't using it now.
Old May 3, 2003 | 12:17 AM
95seMax's Avatar
whats the EGR system , how do u check and clean it
09maxshawn11
Sep 30, 2015 10:28 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
DayHeyZeus
Sep 11, 2015 03:17 PM
