my car just shuts off while driving *** HELP PLEASE***
Hey wuts up guys. Please let me know what is going on with my car.. . since past 3 weeks. I will be driving the car and whenever I would slow down abruptly my car would just shut off. I can restart the car again with no problem but when ever i come to stop from higher speed my rpms goes below 1 rpm fluctuate and sometimes the car just shuts of.. any body else ever encountered this problem if yes please post the solution i will greatly appreciate
-Sal
-Sal
I used to have that similar problem but my check engine light was never went on. It turned out to be my MAF sensor. I replaced it with a used one from the junk yard and my problem went away. I hope that it is something simpler for you. Good luck.
Chan
Chan
Re: my car just shuts off while driving *** HELP PLEASE***
-Sal
-Sal
But if it were any of my other cars, I would be looking for vacuum problems.
Clean your throttle body. Go to www.motorvate.ca for instructions.
Mine did the same thing for the past while. cleaned my throttle body really good last Thurs. hasn't happened yet. Exact problem like you, I'd brake from a good speed on say a turn or to a stop and my rpm would shoot way down and then bounce up..or turn the car off. Trying cleaning you throttle body for sure, that fixed mine.
I'm having the same exact problem...really sucks when you're doing 70 on the highway too!! I think mine is the IACV sticking, but I'm having a helluva time taking it off, I can get the front screw off, but the other one does not want to come off....any trick to this, or am I going to have to take off the entire TB?
CHECK your MAFS wiring thoroughly!!! ...and I mean THOROUGHLY!!!
I had similar issues -- car shutting off, poor fuel economy, etc. --
and it turned out that the main wiring loom near the passenger side
firewall had cracks wires in it without ever being opened!!!
Because the main wire loom takes a deep bend there, the wires get
compacted and with the engine moving over the life of the car the
wires get bent back and forth and some break! This can also happen
if you get the wires wet and then they freeze -- the casing can
crack and the exposed wires slowly degrade.
Check your wiring...Right near the passenger firewall, where the main
loom bends, give the wire a gentle tug/shake with the car running...
If your RPMs change, your wiring could be damaged near that point.
Hope this helps,
FLO_BOY
Hope this helps,
FLO_BOY
Hondarydr
Dec 30, 2024 06:15 PM
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
erniel
Aug 8, 2015 09:32 AM
yat70458
Aug 3, 2015 01:16 PM
