0704: crankshaft position sensor? what to do?
Old May 5, 2003 | 04:10 PM
vinny1978's Avatar
0407: crankshaft position sensor? what to do?
this is what i got when i self diagnosed my car. 0407: crankshaft position sensor. what does this mean and what do i have to do to fix the problem. i got the engine light when i had a really tough tiime starting my car. I still have a tough time starting my car. What is the car doing?
Old May 5, 2003 | 04:48 PM
vinny1978's Avatar
anyone??????
Old May 5, 2003 | 08:49 PM
tm96max's Avatar
My friend had that problem too. There is a sensor right near the lower pully of your engine, it is near the oil filter. He cleaned it off because it was full of grime, prolly from the road and dust. It worked and he has no problem since.
Troy
Old May 5, 2003 | 09:04 PM
KWheelzSB's Avatar
Determine if it is the POS or REF sensor (Hayne's manual will tell you).
Remove the sensor from the transmission bell housing, clean the tip with a clean cloth or paper towel, re-install sensor, reset ECU & start the car. Observe start performance.
If that doesn't work, you need to test the sensor using a digital multimeter. If you're unfamiliar with this procedure, again, a Hayne's manual will explain it rather well.
Old May 5, 2003 | 09:16 PM
UTIMaxima's Avatar
Crankshaft Position Sensor tells your computer when your piston is at TDC so it knows when to fire.
TallTom
57
Oct 14, 2025 05:16 PM
hayne
Oct 5, 2015 11:53 AM
salty318
Sep 28, 2015 07:22 PM
zmcneely13
Sep 26, 2015 02:26 PM
