can someone dissable the rev limiter?
Old May 6, 2003 | 05:45 PM
plurco's Avatar
I know you can dissable the speed sensor on non SE modles, is it possible to do this with the rev limiter?
Old May 6, 2003 | 06:12 PM
s0ber's Avatar
what rev limiter???
Old May 6, 2003 | 06:15 PM
plurco's Avatar
Originally posted by s0ber
what rev limiter???
the 6550 rpm rev limiter.
Old May 6, 2003 | 06:17 PM
s0ber's Avatar
get a JWT ECU
I dont think its too good of an idea to go over 6.5k anyways, not without some modifications to your internals so you dont break nothing!
Old May 6, 2003 | 06:18 PM
plurco's Avatar
get a JWT ECU
without getting a JWT ECU.
s0ber's Avatar
cant
Old May 6, 2003 | 06:21 PM
plurco's Avatar
cant
you can never say "can't" you can only say "can't be done easliy"
Old May 6, 2003 | 06:25 PM
s0ber's Avatar
ok
can't be done easily
Old May 6, 2003 | 07:08 PM
mzmtg's Avatar
Minister of Silly Walks
Re: can someone dissable the rev limiter?
It's the top speed limiter that is removed on GXEs. SE doesnt have one to begin with. I removed my top speed limiter to save weight
Old May 6, 2003 | 07:12 PM
plurco's Avatar
Re: Re: can someone dissable the rev limiter?
Yeah but you know me ben, if i could remove the rev limiter then I could really streatch out that MEVI power band. I am sure it can be done without the ECU. It would be dangerous, but I also have a shift light.
Old May 6, 2003 | 07:21 PM
Ninos_Maxima's Avatar
be the change u want2C
From my knowledge isint this done to Domestics and Rice cars all the time, My freind with a Camaro always brags how easy it is to find cheap parts for his car
Old May 6, 2003 | 07:27 PM
maxspeed96CT's Avatar
The original VQ...
Re: Re: Re: can someone dissable the rev limiter?
Y would a shift light make any diffrance, you sound like a honda owner. I dont think this is a good idea like s0ber said.
Old May 6, 2003 | 07:33 PM
plurco's Avatar
the shiftlight is to ensure you do not extend past 7K while racing.
I can't believe you said i sounded like a honda owner. I have better sense than that.
Old May 6, 2003 | 07:41 PM
s0ber's Avatar
Re: Re: Re: Re: can someone dissable the rev limiter?
Old May 6, 2003 | 07:45 PM
plurco's Avatar
i'm not a kid guys. I was just wondering so that I could try shifting at 7K once or twice. at the track this weekend. I really want to see wy MEVI shine, I do plan on purchasing a JWT ECU soon.
Old May 6, 2003 | 07:48 PM
s0ber's Avatar
I like your car, it looks just like mine!
Old May 6, 2003 | 07:55 PM
xHypex's Avatar
Only thing I can think of is an Apexi RSM (Rev Speed Meter). Also, you do realize that you're still losing power at redline right? The JWT serves several functions: tunes the A/F, increases the redline, and advances timing. The RSM probably costs at least $200 and is really only useful for raising the rev limiter.
-hype
Old May 6, 2003 | 08:12 PM
plurco's Avatar
-hype
the main thing I want to be able to do is shift gears without leaving the VI range.
Old May 6, 2003 | 08:18 PM
xHypex's Avatar
With just a raised/removed rev limiter you'll run slower at the track anyway. The VI is cool, but it's not the solution to everything.
-hype
Old May 6, 2003 | 08:26 PM
plurco's Avatar
i guess I will just hold out till I get the JWT ECU
Old May 6, 2003 | 09:18 PM
optimus310's Avatar
All I have to say is Maximas don't have VTEC. We have The power since we touch the 1RMP , but it goes away at high RPM
Old May 7, 2003 | 04:50 AM
ZuMBLe's Avatar
I have power at high RPMs! =P Many of us do now! Hahaa.
Plurco:
Just wait for the ECU, its safer that way. And the ECU doesn't just raise the rev limiter. It will give you some power all around also. If you decide to definitely get the ECU, hurry and order it. I've been waiting for mine for a month now.
Easy way to go past 6550 without ECU:
Go to second gear at 90 mph. =P I just saw a video of a RSX do that. WOW! The tach like flew past all the numbers and was pointing straight down! No ECU needed for this mod. :P
Old May 7, 2003 | 05:29 AM
deezo's Avatar
They just don't understand that you are using it for a reason.....not rice at all.
Old May 7, 2003 | 05:37 AM
SR20DEN's Avatar
VQ Wizard
FYI: There is no such thing as removing a rev limiter on a EFI vehicle. The limiter can only be raised to a higher point within the limitations of the ECU.
02PearlSE
Feb 1, 2016 12:37 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
JoshG
51
Sep 21, 2015 10:41 PM
