'96 ECU error codes not in decoder
Old May 6, 2003 | 06:30 PM
bassinmax
Took my '96 Maxima SE in for annual MD emissions check and failed - check engine light was on, so no suprise, (at least I get three months of better weather to work on the problems). The test results and error codes provided by the emissions check printout were:
Mil Engine off: Pass
Mil Engine on: Fail
DLC Tampering: Pass
OBDII Communication: Pass
Mil Command Status: Fail
* P0325 - Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
* P0135 - O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
* P1447 - Manufacture's code
I am assuming that the P codes would be the same if I had checked them myself. Can anyone provide addtional detail as to what these mean and what has to be fixed/replaced?
I attempted to use the decoder at http://vbxmaxima.8m.com/ecudecoder.html but it does not go over 13 for the first number nor 15 for the second. Thanks for any input.
Old May 6, 2003 | 08:26 PM
Confused's Avatar
Permanent Maxima.org Resident
Re: '96 ECU error codes not in decoder
From the 96 FSM
Evaporative Emission (EVAP) Control System Purge Flow Monitoring (DTC 0111)
Malfunction is detected when:
EVAP control system does not operate properly
EVAP control system has a leak between the intake manifold and EVAP control system pressure sensor.
Possible causes:
EVAP canister purge volume control valve stuck closed
EVAP canister purge control valve stuck closed
Loose of disconnected rubbber tube
Blocked rubber tube
EVAP canister purge control solenoid valve
Blocked or bent rubber tube to MAP/BARO switch solenoid valve
Cracked EVAP canister
Absolute pressure sensor
Map/Baro switch solenoid valve
Mil Engine on: Fail
DLC Tampering: Pass
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
