will 225/60/15's fit on a stock sawblade?
Old May 7, 2003 | 08:09 PM
cydrive's Avatar
does anyone know whether 225's will fit on a stock 15"? I'm shopping for tires and trying to go wider than the 215.- Cy
Old May 7, 2003 | 08:12 PM
cydrive's Avatar
Re: will 225/60/15's fit on a stock sawblade?
also, i know there's a whole bunch of 225/55/15 tires out there but... is this going to give that detested 4x4 look?
Old May 8, 2003 | 02:36 PM
cydrive's Avatar
Re: Re: will 225/60/15's fit on a stock sawblade?
c'mon people, help me out here!
Old May 8, 2003 | 02:47 PM
95Max's Avatar
You have a 6.5" wide rim and and 225/60/15 will fit.
Old May 8, 2003 | 06:32 PM
cydrive's Avatar
hey thanks man!
Old May 11, 2003 | 09:58 AM
ivelweyz
Since stock tires are 205/60/15 the much wider225/60/15 will mess up your speed. At least get them in lower profile to get things even like 225/50or55/15...
Old May 11, 2003 | 04:45 PM
95Max's Avatar
You will not mess up your speedo. The 205 has a diameter of 25.5 the 225 has a diameter of 25.6 not an issue. I have the 225 on my max and the speedo is correct...and the police say so
Old May 11, 2003 | 06:15 PM
cydrive's Avatar
thanks guys... there was a bunch of 225/50/15 that I was actually looking at and i'd rather go for these if I could but the last thing I want is that 4x4 look..anyone know if it makes much of a difference? Cause I'm thinking its only 10mm what's the big deal..
Old May 11, 2003 | 06:20 PM
cydrive's Avatar
thanks bro! .. hey, i thought the 225 referred to the width of the tire, that the diameter remained the same unless regardless you changed the sidewall height?
Old May 11, 2003 | 07:41 PM
TooMAX's Avatar
What is your stock size? If you have an SE (I'm guessing with your 215/60R15 that you do?), a 225/60R15 is only 1.9% larger than 215/60R15. Within 4% is generally acceptable and not too noticeable. The 225/50R15 is 5.2% smaller than SE tires and 6.4% smaller than stock 205/65R15 GLE/GXE tires. Those will slightly increase the fender gap.
You can play with tire sizes here: tire size calculator Put the tire you want to compare to in first (usually stock size).
Old May 11, 2003 | 07:53 PM
TooMAX's Avatar
Yes, 225 is the width (more or less). The sidewall height changes with the aspect ratio of the tire. what the sidewall numbers mean
9aj9
Apr 5, 2020 12:11 AM
Violator
Sep 9, 2015 10:14 AM
carid
Sep 9, 2015 05:06 AM
