99 Maxima ECU
Old May 8, 2003 | 02:38 PM
RichMax's Avatar
Boosted like Snipes tax refund
99 Maxima ECU
What's the easiest, cheapest way to get at the codes it's throwing off? Apparently my ECU is new enough that the old "screwdriver trick" doesn't work (there is no screw on the outside of tbe ECU, though there is a slightly different sticker covering two of the holes.
Old May 8, 2003 | 02:55 PM
mrb23's Avatar
you could always get an obd2 code reader from pep boys. Forgot how much, $150? or so? do a search for code reader
Old May 8, 2003 | 03:25 PM
drewm's Avatar
That hole with the sticker closest to the front of the car is the one you want, poke a hole in it and the screw is in there. Take a flashlight and look in it, you should see the screw.
Old May 9, 2003 | 12:56 AM
2KxSEx's Avatar
It's a small phillips(sp) screw so find a small driver and go at it Gently
Old May 9, 2003 | 06:15 AM
slfalco's Avatar
On my 99 SE, I found I could only see the screw by using a mirror and a flashlight - Angle the mirror, and shine the flashlight at the mirror so the light then reflects directly into the hole - you will see the screw, it is tiny. On mine, there was a weird toothed wheel thing on the outside of the screw, but I didn't mess with that. The screw is inside that little wheel... A real crappy place to put it in my opinion, of course why make it easy, right?
Old May 10, 2003 | 10:23 AM
RichMax's Avatar
Oddly enough (maybe I'm too big or something) The angle to reach the ECU is EXTREMELY ODD. I have NO IDEA how the guy who did the write-up about the ECU check reached his. Mine is mounted as close to the firewall as possible, making it hard to get to. The accelerator pedal is right in front of the hole.
Question: Your sticker (in a 99 Max) should look different than that in the ('95 I think) referred to in the write-up. I know mine does. My sticker says "IDLESPEED ADJUST" where the sticker photographed in the '95 write-up says "Self-Diagnosis" The same opening is labeled "High" and "Low" with arrows indicating a calibration can be made using turning a screw clockwise and counter-clockwise. How deep do you have to get a screwdriver into this hole, and do all of your stickers covering your holes look the same as mine?
I've stuck screwdriver blades between 1/2 and 1.5 inches inside to no avail (it hit nothing)...
Old May 10, 2003 | 11:42 AM
mymaxlvsattn's Avatar
slackass
the screwdriver is phillips and very small...the smallest one you can find (eyeglass screwdriver size) and be very gentle with it..the screw is plastic and can be damaged if too much force is applied.
Old May 10, 2003 | 12:17 PM
fisher01's Avatar
I have the same ecu. Yes its possible to obtain the the codes.
The small plastic screw is located downward and to the left of the opening. You must use a small phillips screwdriver (the type for eyeglasses) and angle it to reach the screw. I pressed down on the accelerator to give me a little more room. Be gentle in turning the screw back and forth. It was tough to do the first time but keep trying, you'll get to it.
Old May 10, 2003 | 04:43 PM
RichMax's Avatar
Thanks yet again, all.......
Because I'm betting even money my gas mileage problems are due to ks and or O2 sensor....
Pay Howard University $1500, or get upgrades for Max?
HMMMMMMM.........
maximaham
Aug 7, 2015 01:11 PM
1992maximase30
Aug 5, 2015 09:27 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
