Wheel Vibration at 60+ MPH
Old May 10, 2003 | 12:35 PM
max808's Avatar
I get a slight wheel vibration at speeds above 60 MPH. Any ideas? I had my wheels balanced twice and aligned. Also, all new tires. It vibrated before doing all the above.
Old May 10, 2003 | 01:33 PM
DigitalTexan2u's Avatar
Re: Wheel Vibration at 60+ MPH
Could be a bent rim (my problem after this past shizzy winter!!)
or...take it back and get it balanced again!
I had to take my Max back to NTB **3** times before "Cletus" figured out how to balance a tire
Old May 10, 2003 | 03:51 PM
KDLMax
ITS YOUR TIRES! Get it balanced with a good machine. I believe there are two types of balancing machines. One is better then the other. Go find out!
Old May 10, 2003 | 09:15 PM
Stillen_I30's Avatar
hunter 9700 is the machine you must ask for as this is supopsed to be the "better" machine. i believe its called a "roadforce balance." otherwise, it could be other things...i posted about this same problem on my aftermarket rims, and some even suggested warped rotors, or bent axle rods causing this.
02PearlSE
Feb 1, 2016 12:37 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Bonka
Sep 14, 2015 11:18 PM
jcvgn
Sep 10, 2015 08:03 PM
