Minor cuts + Bruises + 20mins = Changed Fuel Filter
Old May 10, 2003 | 05:23 PM
JsL's Avatar
JsL
I finally got off my a$$ and changed the fuel filter. The spark plugs were just changed last week. The car has 54,6xx miles on it and I don't think the filter has ever been changed. It took about 20mins. I took off the intake, then with numerous pulls, the fuel filter. It wasn't as hard as I thought it would be. Fuel did spill everywhere, but I had old T-Shirts under the filter to absorb it.
I started the car, and noticed a deeper idle exhaust and louder hissing from the intake...sounds cool!! Drove the car and noticed better throttle response and maybe a little more power also. I am very happy that I changed it and I regret not doing it before.
Now...everyone go outside and change it!! It's really not as hard as you think
Old May 10, 2003 | 06:50 PM
nupe500's Avatar
Jedi Knight
next on my list of things to do...that and the plugs...
Old May 10, 2003 | 07:02 PM
aznsap's Avatar
hey cool. how often are these supposed to be changed? i was thinking of changin to a 300zx fuel filter sometime in the future.
Old May 10, 2003 | 07:07 PM
aznsap's Avatar
i don't see the email link by your name. is there a charcoal homelink visor available?
Old May 10, 2003 | 08:26 PM
patel_anu's Avatar
i did mine today and took me about 20 minutes also, makes a big difference afterwards, my fuel filter hasn't ever been changed and i'm at 104k...needed to do it badly but its done now i also recommend everyone to do it if they haven't already
Old May 10, 2003 | 08:31 PM
Juki5536's Avatar
Should I get an OEM filter, or what kind and from where?
Old May 11, 2003 | 03:48 AM
maximaseefu's Avatar
oem is good, i think i will upgrade to the 300z filter this time.....be prepared for some bloody knuckles and lots of cursing...........ahhhhhh, memories.
Old May 11, 2003 | 04:12 AM
ivan25's Avatar
Oh my I just changed my oil,cleaned my throtle body, and got a new fuel filter..Darn My car now has a lot more low end..I should have done this sooner..It feels like a new car,you can feel the differnce.
Old May 11, 2003 | 05:25 AM
pruizgarcia's Avatar
I been working on the car this weekend and so far have changed plugs, fuel filter, oil, PCV valve and cleaned the K&N filter. I also cleaned the trottle body and adjusted the idle. Drives like new now. Next week going to change the knock sensor; got a good deal on one on Ebay. Car has 64K miles.
Pedro
Old May 11, 2003 | 09:52 PM
JsL's Avatar
JsL
UPDATE
I took apart the filter and I wish I had a camera so I could take a pic of it. The filter element is BLACK and seems like there is sludge in the filter. It's been 54,8xx miles.
If you see my filter, you will want to change yours immediately!
BTW...taking apart the filter for fun took 30 mins
Old May 11, 2003 | 10:13 PM
aznsap's Avatar
ewwww that's gross....... i don't think mine has been changed in 71,xxx miles. anybody know where i can get a 300z fuel filter? we can use those rite?
Old May 12, 2003 | 12:22 AM
Max Noob's Avatar
i changed mine today.. did that and cleaned the TB at same time.. i dunno why all you guys had bloody knuckes it was easy if you just take off your MAF and airbox first then pull off the fuel filer hoses. also i dissconnected my fuel pump fuse and tried to start teh car a few times to release the fuel pressure and not have soo much fuel leak when u get the hoses off. ??.mayb its just me. i put in and oem nissan 3z filter. damn that thing is big..didnt notice much of a difference though.. jsut revs up smoother from 1-3 k.
Old May 12, 2003 | 12:37 AM
BigJuice's Avatar
I have it on the list of things to do this upcoming weekend along with Oil, Plugs, Put in my new (hopefully it will arrive this week) Frankencar intake, FSTB and OBX Catback (supposedley on its way also). I got to do the PCV valve too.
Is there an added benefit in putting in a 300ZX filter?
Old May 12, 2003 | 12:46 AM
CASS98SE's Avatar
Re: Minor cuts + Bruises + 20mins = Changed Fuel Filter
Changing fuel filter isnt hard, but I went to the emergency room while dooing mine.!! Be careful if you decide to cut the line with a razor! Watch those fingers!!
Old May 12, 2003 | 01:02 AM
EZEMaxima's Avatar
I changed my oil, oil filter, fuel filter and PCV valve last wednesday and it only took me an hour to do it. Now i gotta go get some new set of sparkplugs....
Make sure you release the pressure of the fuel lines by removing the fuse for the fuel pump under the dash and cranking the car a few times until it won't start and then start removing the fuel filter by twist and pulling at the same time.
Old May 12, 2003 | 01:06 AM
Max Noob's Avatar
3z filter is just bigger.. like 2x bigger..fits on perfectly(the mount that holds the stock one stretches) only reason this is an "upgrade" is because its bigger.. hold more fuel, so it should be more responsive when u stomp..and longer filter change intervals more room to hold deposits. and im guessing a filter for a 3z should have better fuel flow then a max..but i duno bout that assumption. its prolly made of the same stuff. it looks cool though.
Old May 12, 2003 | 03:19 AM
You can also get the filter at your local Autozone, Pep Boys or Discount Auto. That sucker is big.
Pedro
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
aminus21
Sep 12, 2015 04:53 PM
thenewguyy
Sep 12, 2015 11:12 AM
sdotcarter
Sep 2, 2015 09:53 PM
