95 engine coolant temp sensor
Old May 11, 2003 | 01:37 PM
95SE_loaded's Avatar
My ECU code indicated that the engine coolant temperature sensor is bad. Is this something that I can replace myself, and where is it located? Thanks in advance.
Old May 11, 2003 | 09:13 PM
DougAtoms's Avatar
You should be able to replace this yourself. It's located between the battery and the intake manifold looking down near the block. The sensor points practically straight up (connector up). Removing the sensor breeches the cooling system so let the engine cool and drain off a little coolant first to lower the coolant level below the the sensor.
Old May 11, 2003 | 10:32 PM
lunchbox's Avatar
I just changed mine. I did it right out in front of auto zone. Its easy.
Old Jun 26, 2003 | 11:39 AM
MoogieBoogie's Avatar
Does anybody have a picture of where it is and what it looks like? Is it a simple swap?
Thanks,
-Brian.
Old Jun 26, 2003 | 11:53 AM
Dreizehn's Avatar
Thanks,
-Brian.
There are two there, one is for the gauge and one is for the ECU. The one for the ECU is the larger of the two.
Old Jun 26, 2003 | 02:42 PM
MadMax, nice engine bay. What intake kit is that?
Is it a simple removal and reinstall? I reset my ECU to see if the code will trigger the MIL again. Thanks for the picture.
-Brian.
Old Jun 26, 2003 | 02:59 PM
Dreizehn's Avatar
-Brian.
Thanks...
It's a Stillen pop and Frankencar midpipe...
It's pretty simple to remove and install another one.
MR2 T'd
Jul 9, 2021 05:06 AM
mvm062
Nov 30, 2020 09:00 AM
captchaos
Mar 15, 2016 12:18 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
