Rubbing noise when brakes applied in reverse
Old May 12, 2003 | 06:24 PM
wilked's Avatar
When I back up I hear a rubbing noise coming from the brakes. This only happens when going backward. Is this the wear indicator???? I am going to pull the wheels this weekend and take a look, but thought I would throw it out here. I have only had the car for less than 10K so I am assuming they are original (car just passed 60K). Also, if so what pads should I go for?
Old May 12, 2003 | 06:26 PM
RobUsaf81's Avatar
is it like a groaning noise? if it is, its your parking brake sticking. I get that noise all the time and i hear the only way to fix it is with new steel braided brake cables or something like that.
Old May 12, 2003 | 07:25 PM
wilked's Avatar
Ya, definitely groaning. You can't just grease up the E-brake and work it back and forth???
Old May 13, 2003 | 12:30 AM
Bgohan's Avatar
If not worn pads,
groan could be from.........
If your wheels are getting wet while parked, the noise is surface rust on rotor.
If you recently installed a rear sway bar, it might have tightened up your brake cables, and therefore your rear brakes got snugged up a little.
Brakes got contaminated with something. Look for leaks.
Something could be loose. Doubt it.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
