5 speed tranny flush
Old May 13, 2003 | 05:54 PM
Max Noob's Avatar
how often should i flush/change 5 spd tranny oil.. what oil do i use..everyone is prolly gnnna say redline..so second to redline(its expensive and hard to find) what oil should i use.. thanks..
Old May 13, 2003 | 06:06 PM
mtrai760's Avatar
'Trynna' is not a word
You should change the tranny fluid every 30k miles, there is no flush for a 5spd, unless you just wanna waste tranny fluid. While a high performance fluid like redline can be recommended, you could just go with a standard GL-4, which is the fluid type specified for the maxima, do NOT use anything else. Hope this helps.
Old May 13, 2003 | 06:14 PM
Max Noob's Avatar
30k huh..think im overdue..thanks
Old May 14, 2003 | 06:13 AM
StygianMax's Avatar
I've heard good things both about Red Line and Amsoil. I've used RL's MTL and the shifting improvement is like night & day! Since you're in Cali, you might be better off with MT-90. I've read people putting in Amsoil 75W90 at a much cheaper price than MT-90. Around here, the price difference can be Amsoil being 50% of Red Line's MT-90 cost.
It's relatively easy to change the fluid yourself. Here are my pics/process for changing tranny fluid.
Old May 14, 2003 | 07:01 AM
CheshireCat76's Avatar
I need to do this.
Wheres a good place to get the Redline?
Also, how much do I need?
Old May 15, 2003 | 06:57 AM
iwannabmw's Avatar
Originally posted by CheshireCat76
I need to do this.
You need to buy 5 quarts.
Old May 15, 2003 | 01:01 PM
Max Noob's Avatar
whaooo.thanks alot for the link to the faq.. gotta loook for some red line tranny fluid now.. links anyone?
Old Jul 9, 2003 | 06:27 AM
Just ordered some MT-90 from www.myoilshop.com
Good price. $7 a quart.
Old Jul 9, 2003 | 01:04 PM
slfalco's Avatar
A word of warning.. When I tried to drain my 99 5sp by removing that plastic sensor thing, I removed the bolt, placed a screwdriver under the thing to pop it out, and proceeded to instantly snap off the tab where the bolt went through. I quickly glued it back on and put the bolt back in, and then found an alternate (though incorrect) means to drain it (couldn't find the actual drain plug, ended up removing the bolt that holds in the 1-2 shift ball/spring). That ended up not draining all the oil, so I had to suck out the remainder using a mityvac. Talk about learning from experience... I used the Redline MT-90, seems fine...
Old Jul 9, 2003 | 01:12 PM
StygianMax's Avatar
Sounds like you had yourself some experience!! I just helped a buddy drain the tranny fluid from his 5-spd through the drain bolt. We used a 12mm open ended wrench & it worked great.
Old Jul 9, 2003 | 01:17 PM
slfalco's Avatar
Yep, it was fun... But still better than paying someone else to do it. I just could not see anything that looked like a drain bolt, all the bolts looked to me like they held the 2 tranny halves together. Next time I'll find that sucker!
Old Jul 9, 2003 | 01:44 PM
StygianMax's Avatar
The drain bolt is located on the passenger side of the tranny case. It's in a really hard-to-reach place. It's the silvery colored bolt about 1/3 up from the bottom of the picture and to the right of the black brace that runs up-down. The bolt head is right where the brace takes a jog to the left:
Hope this helps. Once you look under your car next time, things will make more sense.
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
