0103 Coolant Temp Sensor replacement
Old May 14, 2003 | 07:58 AM
NmexMAX's Avatar
dot dot dot ...
How difficult is it to cahnge the Coolant temp sensor on a 95? Jsut wondering, b/c my cel turned on yesterday and gave me a 0103.
Old May 14, 2003 | 08:23 AM
Dreizehn's Avatar
There are two sensors, one for your dash and one for your ecu. They are both located in stream with each other, circled in the pic.
Since you got the CEL, it's the larger of the two. I think it's the one closest to the rear of the car.
Now is a good time to flush the radiator being that you should drain some of the fluid prior to removing the sensor. Some people have been able to change it without draining the fluid, but it's suggested in the chilton.
Just unplug and remove the old one and replace with a new one. Pretty simple.
mrc00l88
Jan 25, 2024 01:14 PM
Justinmc760
Aug 23, 2015 03:10 AM
Maxboy23
Aug 21, 2015 11:02 AM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
