Tough to shift into first...
Hey guys, I got a question - My max is been tought to shift into first while moving any faster than 2 mph. It's really easy to put into gear from a stop but if I am rolling i cant get it into first without fighting it? Any Ideas?? Thanks.
Originally posted by 96BLUMAX
Yep mine does it too. Its normal.
push in the clutch,
put it in Neutral,
push the shifter against the 1st gear entry point... NOT TOO HARD,
let off the clutch,
push in the clutch and you should then be able to put it in gear.
The whole sequence should take 2 seconds.
This takes some practice... and slippery synthetic lube.
If you can't get it to work for you after a few attempts, stop trying and accept that you have to stop to grab 1st. Don't wreck your tranny.
heh i got the same problem. I find myself trying to shift to first. I did force it a few times. Then i just started using 2nd for quick turns... works alot easier... (When i first learned to drive my mom was in th passenger seat, and i shifted and let the clutch out to early and my little 3 pound dog went flying into the dash)ROFL! I feel bad but hey, we live and we learn right?
Yea, if you revmatch you can probably get into first a lot easier BUT revmatching into first is tricky because you have to be really really exact. It's tough to get it revved to a point where the shifter will go, and fall to the right level just at the right time so you don't start bucking when you release the clutch.
The best way to rev match is to double clutch. To do this...
1.) Press clutch and put gear lever in neutral
2.) Blip throttle to correct rpm (requires lots of practice in any gear)
3.) Quickly press clutch and put gear lever into new, lower, gear
4.) Release clutch.
If you do it right you can just dump the clutch, but for the LOVE OF GOD don't start dumping the clutch the first time you double clutch into first. In fact don't start dumping the clutch into ANY gear until you get good at it. If you want to learn this start with 5->4 and work downwards. Honestly though, you shouldn't be downshifting into first if you're moving more than a couple miles an hour. It's just not necessary.
Once you get good at it you can start heel-and-toeing. You can actually revmatch without double clutching (just shift normally and goose the gas in between gears) but my rudimentary understanding of how the 5 speed works tells me that this will kill your synchros. Used to do it all the time but now I am trying to learn to double clutch and heel-and-toe at the same time for maximum safety and smoothness. There is NOTHING like hitting a perfect heel-and-toe downshift into a tight corner...
4.) Release clutch.
If you want to be able to go in 1st at a 10mph+ roll, simply double clutch the correct way and the shifter will go in smoothly.
Double clutch:
1) Clutch in
2) Shifter to neutral
3) Clutch out
4) Clutch in
5) Rev match
6) Clutch out
Dave
Double clutch:
1) Clutch in
3) Clutch out
4) Clutch in
5) Rev match
6) Clutch out
Dave
Double clutch:
1) Clutch in
3) Clutch out
4) Clutch in
5) Rev match
6) Clutch out
Dave
Double clutch:
1) Clutch in
3) Clutch out
4) Clutch in
5) Rev match
6) Clutch out
Dave
At least that's what I think. If there's a reason why this theory is wrong...lay it on me. I really didn't udnerstand the modern 5 speed completely until i checked this site out...really really nice diagrams of an oversimplified 5 speed...
http://auto.howstuffworks.com/transmission.htm
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
