Need Installation Instructions for KYB AGX's
Old May 15, 2003 | 12:16 PM
MikeD95SE's Avatar
Hello,
Im planning on installing my KYB's on Saturday. Does anyone have a writeup on how to install them. I have installed the Konis a while back and I cant remember much about how to do it.
Thanks,
Mike
Old May 15, 2003 | 02:43 PM
spiff56747's Avatar
Re: Need Installation Instructions for KYB AGX's
Originally posted by MikeD95SE
Hello,
Thanks,
Mike
If you've done Koni's, I think it should be a lot simpler to install KYBs. Didn't the Koni's have to be cut in some way?
Anyway, just take out the whole spring/strut assembly, put on a spring compressor (you only need it for the fronts), undo the top bolt on the strut and it pretty much just comes apart. Just make sure to put everything back the same way, and you might wanna replace strut bearings and dust boots.
Also, make sure you tighten up the top bolt to the proper spec when you're done, mine was loose and that was the source of pretty much all my suspension noise.
Are you going with stock springs btw?
Old May 15, 2003 | 05:40 PM
MikeD95SE's Avatar
Re: Re: Need Installation Instructions for KYB AGX's
Thanks brother.. Yeah the Konis were a pain in the A$$. I bought some chopped suspension techniques a while back. Ill post pics when it is complete.
BkGreen97
Apr 2, 2016 05:47 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
dvcamp
Sep 18, 2015 10:17 AM
