fuse(brighter corners)
Old May 16, 2003 | 10:23 PM
minsbang's Avatar
I just made my corner lights brighter by cutting off the upper nub of the bulb. I went out and bought 10A fuses and i don't know where the location is. Is it the one near the battery ? can anyone help me on this one?
((99MaXsE))
Old May 16, 2003 | 10:27 PM
nadir_s's Avatar
vicodin ... gift of life
why are you changing it to a 10A fuse? did it blow? If not, why would u want to change the fuse?
The only thing u need to worry about are those overheating bulbs eventually making a "bubble" shape on you plastic lens corners.
The fuse is located inside the cabin, underneath the steering wheel on ure left. I think it's the one marked w/ the Taillamps.
Old May 16, 2003 | 11:03 PM
minsbang's Avatar
I am chaning the fuse because the bulb will be running more power. It's suggested that the fuse is changed so that it can handle more wattage that's being run through. It uses the same fuse as the taillight and if the 7a fuse gives up, then your taillights will be out. i don't wanna get pulled over for something like that.. it didn't blow yet. i had it for two weeks now. I figure it's not hard so i'll just take 5 mins to do this.
Do you know any1 that got a "bubble" due to the heat?
By the way, Are those Projectors i see on that black max? i have a 99se and i was wondering how you did that.
Old May 16, 2003 | 11:20 PM
nadir_s's Avatar
don't change it if hasn't blown. That's not how a fuse works anyways... it's a safety device that only cuts the power off if there's a power surge or the Amps are too high. Wattage doesn't matter in your case, the only damage that would do is over heat the bulbs.
I have seen pictures before on here w/ people who have had bubbles formed or some sort of damage (even minor) done to their plastic lens because of the mod. Since I don't see people complaining about it much, I guess it is ok, as long as you don't do alot of night driving.
As for the projectors... i guess the picture only looks like that, but I can only wish to have em
Old May 17, 2003 | 12:25 AM
Mad Dhan's Avatar
i never changed anything and they did not blow any fuses. I actually disabled them now casue they did not match my HIDs and they are pretty much useless anyway
Old May 17, 2003 | 01:02 AM
minsbang's Avatar
ok, so maybe the fuse will not blow..But i have a couple of 10a fuses lying around. i will change the fuse. i heard the fuse box is under the hood, near the battery.. is this true??
Old May 17, 2003 | 05:00 AM
Ninos_Maxima's Avatar
be the change u want2C
Ive had mines on for 3 months now, Now problems
Old May 17, 2003 | 07:17 AM
minsbang's Avatar
i want to change my fuse. i have the fuse with me.. i want to be on the safe side..
Old May 17, 2003 | 10:13 AM
nadir_s's Avatar
what safe side?!??!! while you're at it, change all the other fuses then too.
putting in a higher fuse = NOT SAFE
and i told you, the fuse you are looking for is INSIDE the car, underneath the steering wheel marked taillights.
Old May 17, 2003 | 10:51 AM
aznsap's Avatar
hey, i blew the fuse to my rewired corners once. it was while i was driving for quite a while at night. at any rate, it' sa 7.5 amp mini fuse btw. i replaced it with that, and i haven't had any problems.
Old May 17, 2003 | 10:55 AM
philly96maxima's Avatar
Replace your fuses with higher amperage ones... the bulb will not burn brighter, but your wireing harness might!
Old May 17, 2003 | 04:29 PM
minsbang's Avatar
ok, i changed the fuse today to 10a. let's see what happens...
Old May 17, 2003 | 04:35 PM
Allen's Avatar
car-wise, you're stupid. most people that are stupid compensate by listening to others, maybe you should give that a try.
Old May 17, 2003 | 04:53 PM
dave harms's Avatar
lol
Old May 17, 2003 | 06:58 PM
minsbang's Avatar
hey, i'm just asking... i'm sure if you asked a question on a specific topic, some1 else would think the same for you too. so don't hate.
Old May 17, 2003 | 07:09 PM
DigitalTexan2u's Avatar
you DO NOT have to "upsize" the fuse UNLESS it blows!!
I did this mod some time ago and i've had ZERO problems.
Old May 17, 2003 | 07:47 PM
Juki5536's Avatar
What if you actually get brighter aftermarket corner bulbs?
Old May 17, 2003 | 08:32 PM
kaniksu's Avatar
Don't ask for advice if you are not planning on listening to it. I am not sure why you have such a hard on for changing a fuse anyhow...
Old May 17, 2003 | 09:11 PM
nadir_s's Avatar
it doesn't matter, it will be the same... only difference will be the wattage and the wires tend to burn hotter and could possibly melt.
leatherneck
Sep 30, 2015 09:16 PM
Blkkn8
Sep 22, 2015 06:37 PM
conansriver
Sep 16, 2015 12:17 PM
