How to change setting on KYB AGX
Old May 17, 2003 | 12:14 PM
Ceasars Chariot's Avatar
Old Maxima Legend
KYB AGX Question ??
Just a quick question. How do you change the settings on the front shocks and the back ?
Old May 17, 2003 | 12:21 PM
taeMAX97's Avatar
Front : With flathead screw driver that they gave you. Press down and turn it to the setting you want.(It's on the top)
Rear : Just turn the **** to the settings.
Old May 17, 2003 | 12:41 PM
Old Maxima Legend
thanks, it seemed so easy it was hard to believe..
Old May 17, 2003 | 12:47 PM
paulsfds's Avatar
yea for the front all you have to do is pop your hood and for the rear you have to jack up your car to reach the ***** but it's still a simple and easy process
Old May 18, 2003 | 08:39 AM
1996blackmax's Avatar
Re: How to change setting on KYB AGX
Originally posted by Ceasars Chariot
KYB AGX Question ??
Just remember that when adjusting the front struts with the flathead screwdriver you have to push down and then turn, otherwise you could brake the dial. Once you reach the setting you want, the dial should pop up, if not then turn the dial a little more (back or forth depending on whether you went too far or not far enough).
Old May 18, 2003 | 11:18 AM
vmok's Avatar
Adjusting AGX
I installed my AGX several months ago, and no matter how hard I push down on the front adjusting screws, they don't want to turn. Is there a specific trick? Anybody in the SF south bay or bay area want to give it a try?
Can I possibly have defective struts?
-V
Old May 18, 2003 | 06:25 PM
Re: Adjusting AGX
-V
If I still lived in Vallejo I would help you, but I am a good 500 miles away now. For my strut adjustments I don't have to push down hard at all. Just turn very slightly(and I emphasize, very slightly) and push down, sometimes it seems as if a very small turn might help it go in as you are also pushing it down, just not too much though as the sheet it comes with states that this will damage them(turning without pushing down). Kind of like the dial having to find its groove. I hope this makes sense, it's kind of hard to explain. If this does not work maybe they were damaged during the install, if they were banged up when they were being put in. I had to remind the shop that put in my struts about the dials on the struts, as I had read a post where an Org. member had his damaged by the technician in this way. Good luck.
Old May 19, 2003 | 12:17 AM
vmok's Avatar
Re: Re: Adjusting AGX
Thanks for the tip. I'll try twisting slightly as I push down on the adjusters. I installed them myself with the help of a friend when we were doing my clutch, and I'm sure that nothing was banged on or damaged in any way during the install. I'm quite **** about my stuff. I'll give it a try in the next couple of days and let you how it goes!
-V
pktaske
May 6, 2016 07:49 AM
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
sdotcarter
Sep 2, 2015 09:53 PM
