sad-depressing-gloomy-miserable-heartbreaking NEWS about my max
Old May 20, 2003 | 07:05 PM
delacruz_17's Avatar
I have three fault codes my car will not pass inspection with the check engine light on.
1.P0325: Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sens
2.P0505: Idle Control System Malfunt
3.P0600: Serial Communication Link Malfunct
Well for the 1st problem i was told to check the cables or replace the knock sensor.
2nd fault code i was told to clean the trottle body with some carburetor.
3rd well no one could give me a straight answer. All i was told was to check the ground cables. I don't know where to start checking the cables all i see for ground cabeling is at the battery.
Is this how i should approach these problems? Any tips from anyone would help alot. o yea i have a 96 auto max
Old May 20, 2003 | 08:38 PM
1996blackmax's Avatar
Re: sad-depressing-gloomy-miserable-heartbreaking NEWS about my max
http://www.motorvate.ca/mvp.php/507
This web site's shows you where the grounding cable for the knock sensor is, as well as showing you how to replace it. It is a great web site for the home mechanic.
Old May 20, 2003 | 10:23 PM
wow great site, ummmmm does anyone know where the "A/T control unit" is located. Cuz i got the check engine light flash code 0504
Old May 20, 2003 | 11:17 PM
Oakley02's Avatar
take out the bulb for the light to get it through inspection lol
Old May 20, 2003 | 11:30 PM
nadir_s's Avatar
vicodin ... gift of life
HAHA that is a great idea if you just want to get passed inspection...
Old May 20, 2003 | 11:39 PM
naw they check your computer, even if your light is on or off. The law changed in Texas requiring all inspection stations to make mandatory checks on the ECM
Old May 21, 2003 | 01:59 AM
carnal_c30's Avatar
Former Sponsor
pull the bulb for ure CEL out ehehe
oh well I know you cant because they scan the computer... have you tried to clear your ECu and see if the codes pop back up??
hey and dont worry about it... my Maxima hasnt passed smog since August 2002 ahahahaha
Old May 21, 2003 | 11:05 AM
yup i cleared the computer and they poped up when i drove like 15 miles. I haven't checked what has come up, im about to do that right now.
Old May 21, 2003 | 11:31 AM
kenju4u's Avatar
ohhhhhhhh the 0504 code is a pain cause thats "A/T signal to ECU" i had that signal since the past month and i finally got it fixed at the dealer...you are probably also getting a 0104 (vehicle speed sensor)? thats more the likely your speedo head. cost me $450 at the dealer...the part and calibration itself is around 270 bucks!
Good luck!
Old May 21, 2003 | 11:53 AM
well i just did the self diagnostic and got only two fault codes. 0304 (knock sensor) and 0205 (idel control valve). Not four fault codes like i was getting at the mechanic shop. They cleared the codes and i guess that fixed the other two up.
well for the 0205 i just cleaned the trottle body and i hope the code won't pop up again.
The much dreaded 0304 knock sensor, well i cleaned the ground cables that go to the knock senor shown here http://www.motorvate.ca/auto/maxima/...m_DSC00108.jpg .
i hope these two things will help me get past inspeciton, AT LEAST, since i did already pay 40 bucks and the failed my ***. At least they give u 15 days to fix everything up and come back for free. Im going to go drive around and cross my fingers that the engine light will not come up again.
ps: has anyone else writen a really good responce and then the server tell u it has an error, and you have to write it all over again?
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
