help with shifter?!?!
Old May 22, 2003 | 04:03 PM
cook87's Avatar
i got a 95 max se with 186,000 miles on it... today the shifter started resting in front of second gear instead of right in the center between 3rd and forth.... is this an issue or a sign of problems to come?
Old May 22, 2003 | 04:14 PM
Galager's Avatar
Nah don't worry about it. One of the springs broke that hold it in the center. That happened to me shortly after installing my short shifter and my car only has 57K on it. I've been driving like that for 3 years! If it really bothers you, you can get it fixed but it'll cost like 200 cause they have to remove the exhaust and heat sheild to get to it. Wait until you buy a cat back!
Old May 22, 2003 | 04:22 PM
Flava_24/7's Avatar
Boosted Panda
200.00 bucks to remove the cat. and heat sheild!!! Yikes, its not difficult at all to remove. You can do it yourself.
Old May 22, 2003 | 05:07 PM
Nismo's Avatar
shift return spring is busted. nissan part#34573-40U00 its like a $6 part at nissan. go under the car and you will see a spring that connects the shift control rod to the shift support rod. the spring is about an inch long
Old May 22, 2003 | 07:55 PM
Galager's Avatar
Thanks for that Nismo, I'll take another look, I had no clue it was that easy. I figured it was up where the shifter was.
Old May 22, 2003 | 09:35 PM
Nismo's Avatar
well it technically is where the shifter is which is under the car and above the exhaust. I think you can change it from inside the car though, unbolt the 4 nuts/bolts and take off that large rubber dust boot and you should be able to look down and see where the spring is.
Old May 23, 2003 | 09:35 AM
cook87's Avatar
thanks guys... this is all a big help.. i will swing by the nissan dealership and see if they have the part in stock... its not really a big problem but my wife drives the car too and u know how that can be
Fbana41
Aug 29, 2016 12:18 PM
lux97Max
Sep 28, 2015 11:18 PM
atriuum
Sep 28, 2015 01:19 PM
ef9
Sep 10, 2015 10:35 PM
