blue smoke
Old May 23, 2003 | 03:45 PM
maxima228's Avatar
blue smoke
my maxima smokes blue during startup in the mornings.it on does it for about 30 seconds to 60seconds.sometimes it smokes blue after getting off the interstate.I have a 1996 Se with 148,000miles.any suggestions?
Old May 23, 2003 | 03:49 PM
Mmmaxx's Avatar
"A motor with bad valve guides and/or rings gives off blue tinted smoke"
I googled that, not sure if it applies here or not
more google search shows..that blue smoke is an indicator of burning oil, bad piston rings and/or bad valve seals.
Old May 23, 2003 | 04:43 PM
njmaxseltd's Avatar
I'd place my bets on the valve stem seals. The key is more smoke upon start up, that definately points to leaky valve seals.
Old May 23, 2003 | 08:27 PM
rmb's Avatar
rmb
Re: blue smoke
As they said... valves or rings.
Not much you can do about it though. You'll probably get another 50k out of her if your somewhat carefull. Change your oil frequently and check the level a lot. 200k is about all you can ask from the average Max motor, anything else is a bonus!
Sometimes stepping up the oil viscosity can help once it get's really bad. Only do this though if it's warm out. 20w50 on a zero degree morning is a bad bad thing....
-RMB
tarun900
19
Dec 20, 2021 06:57 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
BobTX10
Oct 7, 2015 08:43 AM
