How do I turn 'AIR BAG' flashing light off?
Old May 23, 2003 | 08:23 PM
TheMax95's Avatar
Anyone know? I reset the ECU but that didn't do it.
-Paul
Old May 23, 2003 | 08:34 PM
clee130's Avatar
Originally posted by Daniel B. Martin
This is the procedure for resetting the dashboard Air Bag warning light.
This information came from the '99 Maxima factory service manual.
Perhaps your '95 works the same way. It's easy enough to try.
Open the driver's door. Note the rubber covered button, a button which is
pressed by the door when the door is closed. This is the Driver's Door
Switch (DDS).
Turn the ignition from OFF to ON. Press the DDS at least 5 times within 7
seconds after turning the ignition switch ON. Turn the ignition OFF.
Close the driver's door. Start the engine.
Possible causes for this warning light to go on include...
- a fault with the Air Bag.
- abnormally low voltage in the electrical system due to a weak battery.
- a maladjusted door striker plate such that the door does not close properly,
and the DDS is jiggled on and off constantly as you drive.
If the dashboard warning light remains on after you perform this reset procedure you may have to let the dealer handle the problem.
Old May 23, 2003 | 09:23 PM
BSwithTF's Avatar
Re: How do I turn 'AIR BAG' flashing light off?
-Paul
Pull the bulb. J/K I had to do that cause I had a salvage car with blown airbags. Hasn't come on since.
Old May 23, 2003 | 09:30 PM
96BLUMAX's Avatar
Yeah dont know of a way other than pulling the bulb. That is what i did cause i dont have a drivers side airbag anymore.
Old May 23, 2003 | 09:31 PM
clee130's Avatar
Switch (DDS).
tsi6001
Oct 3, 2022 10:23 PM
bc992164
Aug 26, 2015 12:19 PM
Samedi
Aug 13, 2015 04:05 PM
kirkhilles
Aug 8, 2015 10:53 AM
