Need Expert help on Wheels...
Old May 27, 2003 | 09:40 AM
taeMAX97's Avatar
Eversince I got my new rims/tires put on my car vibrates after about 60mph... got that damn thing balanced 3 times and got it aligned twice. Finally they found out that i needed a hub rings. Now i called this place up for them and they needed to know the measure of our inner bore(???). Does anyone know what the measure of this is? help me.. i wanna get it over with. been figuring this out for past month...
thanks,
Tae
Old May 27, 2003 | 10:05 AM
taeMAX97's Avatar
bump
Old May 27, 2003 | 11:05 AM
njmaxseltd's Avatar
The rings aren't going to cure your vibrations. They only make it easier to mount aftermarket wheels. If your wheels are put on correctly, slowly tightening the lugs in a cris-cross pattern, your wheel will be centered on your hub.
Go to a different shop and have them balance your wheels.
Old May 27, 2003 | 11:30 AM
sil SE's Avatar
i mounted my wheels with a 73 bore ..and though i have rings , i didnt use them because it was a pain in the ****.
i have no vibrations, and putting the wheels on took a little more effort but it was no biggie.
our bore size is 66.1mm remember it
Old May 27, 2003 | 12:30 PM
Zirafa's Avatar
Perhaps try balancing on this machine
http://128.242.141.111/
Old May 27, 2003 | 01:18 PM
taeMAX97's Avatar
so I don't need to get them? basically they are same as spacers(wheel spacers?)?? im confused.... this is driving me nuts.... after 60 mph
Tae
Old May 27, 2003 | 01:23 PM
waveridr85's Avatar
i get sorta the same problem here,after about 65 it kicks in
Old May 27, 2003 | 01:36 PM
taeMAX97's Avatar
with after market rims???
Old May 27, 2003 | 01:51 PM
taeMAX97's Avatar
so if i do want them(need them) i should go for 73mm instead of 72mm?
thanks,
Tae
litch
123
Jan 4, 2024 07:01 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Sep 21, 2015 12:41 PM
robtroxel
Sep 8, 2015 08:15 PM
