Removing old caliper paint?
Old May 27, 2003 | 11:03 AM
CheshireCat76's Avatar
The paint on my calipers is flaking and needs to come off.
Whats the best way to remove the old flaking paint?
Old May 27, 2003 | 11:10 AM
njmaxseltd's Avatar
Disassemble the brakes completely. All hardware and pads should be off. (Don't take the caliper apart!)
Apply some paint remover, you can get water based paint strippers, let it sit, wire brush it a bit then hose it all off.
Old May 27, 2003 | 12:42 PM
Nismo's Avatar
actually a can of brakleen will strip it off really easy IF you used hi temp paint like duplicolor engine enamel stuff. if you use folia-tec or G2 or some other lacquor then those resist chemicals.
Old May 28, 2003 | 11:56 AM
Yeah I used the the hi-temp engine spray paint.
Old May 28, 2003 | 12:30 PM
redmaxpa007's Avatar
i SeE what you did therE
brake cleeen and a wire brush
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
