Help Identify these wires
Old May 27, 2003 | 11:55 AM
NISMO808's Avatar
I was changing my oil the other day and was wondering if anyone knew what these wires are that are just below the oil filter. The reason I ask is cause they're starting to get kinda gunky (for lack of a better word).
Here are some pics.
pic 1
pic 2
Old May 27, 2003 | 12:30 PM
Chunger's Avatar
My other car is a Hybrid
Crank Position Sensor below crank pulley
Old May 27, 2003 | 12:59 PM
NISMO808's Avatar
is it ok that there's all that gunk near the contact?
Old May 27, 2003 | 01:58 PM
Chunger's Avatar
You can clean up the sensor harness brake cleaner or electrical contact cleaner if you're really worried.
Old May 27, 2003 | 02:09 PM
Turbo95Max's Avatar
Turtle turtle... Moderator
might be from oil residue from your oil filter also. Oh, check your oil pressure switch, most of them time when it starts to leak it soaks that wire with oil...
Old May 27, 2003 | 03:02 PM
NISMO808's Avatar
Thanks for the input guys. Turbo95max you're right about the residual oil from the oil filter cause those wires are directly underneath the oil filter. But I will go ahead and check the oil pressure switch anyway because I do have a small leak somewhere. Every day I find a new drip spat on the concrete. I've replaced the drainplug and gasket so far but problem not solved.
Anyways thanks again guys. gotta love the org.
D Mason
Jun 21, 2016 04:43 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
