Hi-flow cat
Old May 27, 2003 | 09:17 PM
igordlu's Avatar
Hi-flow cat
Any one of you have any advice on what kind of hi-flow cat I should get. Any experience with brands, prices.
Old May 27, 2003 | 09:20 PM
rmb's Avatar
rmb
Re: Hi-flow cat
Survey says keep the one you've got or gut it.... Not many fans of aftermarket cats here....
-RMB
Old May 28, 2003 | 06:26 PM
epik_x's Avatar
Why exactly are there no fans of aftermarket cats here? From what i know you cant go test-pipe unless u have a chipped ECU(ODBII cars)...and from some dynos i seen high-flow cats offer substantial power gains without messing with the ECU.
Old May 28, 2003 | 07:08 PM
drewm's Avatar
It just doesn't help much.
http://drewm.dyndns.org/~drew/maxfaq...yticConverters
Of course you can test pipe, and if your ECU trips, just pull the last O2 sensor, tie it off somewhere and bung plug the hole, so your sensor thinks it's getting clean air.
Also the dyno graph from Random added their cat + a greddy catback, look at the details.
Then again, I've got a Random Cat
Old May 28, 2003 | 08:34 PM
DanIAm's Avatar
def. stick with stock or gut it if anything, i bought a carsound cat and nothing on my car has been more of a headache then that thing, o2 sensor acually broke off the cat, all the stuff inside broke so i had to hollow it and for some reason it still makes an obnoxious noise...just my opinion but stick with da stock cat, do y pipe and cat back and u'll be fine
maxinout93
Oct 31, 2015 02:04 AM
lrb6805
Sep 18, 2015 07:07 PM
Justin Kroll
Sep 2, 2015 11:06 AM
