KYB AGX settings... more conclusions
Old Jun 3, 2003 | 01:09 AM
  #41
drewm's Avatar
Originally posted by max002
3/6 revolution...
So who's gonna be the 3/6 Mafia member #1? I would but me no has AGX
I just know Dave B and I (and probably a few others that slipped my mind) have been arguing this one out for no end. Then again we both have Konis (cept for his rear)
It's just a known fact that when you put a stiffer than stock spring in, you need a stiffer than stock shock setting to dampen it.
Old Jun 3, 2003 | 01:45 AM
  #42
Max Noob's Avatar
does turning stiffness/rebound on the agx high make them wear out faster... i have maxspeeds with 1 cut coil all around.. rides great, i have it at 3/6..doesnt bouce around like civic with cut coils...i wanna turn agx up to 7 or 8 in back but scared it will beat up my schock faster..3 in front is perfect...
Old Jun 3, 2003 | 02:05 AM
  #43
drewm's Avatar
I'm pretty sure it's the opposite. The higher the setting, the more dampening, the less shock movement = less wear. Turn them up, it can only help.
The big killer of shocks is bottoming out though.
Old Jun 3, 2003 | 03:49 AM
  #44
Kanaka's Avatar
I think every car is different and depending on the driver you should tune your AGX's to the correct setting for your car. There are a lot of factors like springs, weight of car/subwoofers, road conditions, driving style, etc. and i think that for you to really get the best setting you need to do a blind test. have a friend adjust your struts, but not tell you what the settings are, then drive it around then have your freind change the settings again not telling you what it is and so on until you find the best setting. that way your mind will not have any preconceived notions about how your car should handle at various settings. just my 2¢
Old Jun 3, 2003 | 06:43 AM
  #45
daveauth21's Avatar
i've been riding on 4/8 for two months now should i be riding on a lower number? and yes it's a very rough ride
Old Jun 3, 2003 | 07:09 AM
  #46
xHypex's Avatar
I've been running 4/8 for a few months as well. I used to run 1/2 in the city with my B&Gs, but sometimes after autocrosses I don't change the settings. Mad Dhan has it right: "The lower the number, the better your car will handle at low speads. The higher the number the better(as well as smoother) your car will handle at higher speads."
Lately I drive a lot on the highway and the ride is great, so I'm sticking with 4/8. It gets a little bouncy on some residential roads where there are many small bumps that are close together.
-hype
Old Jun 3, 2003 | 09:26 AM
  #47
optimus310's Avatar
Well I just try mine at 3/6 and I am not happy. My car is just too bouncy. this morning in may way to work I tried them and is was just no good. way tooo hard. Could it be because I just install my springs about 3 days ago and they haven't settle yet? whatever it is I think 2/4 rides much more smoother at low and high speed.
Old Jun 3, 2003 | 10:41 AM
  #48
mrb23's Avatar
yeah, sometimes the springs or AGXs need to settle first... drive in 2/4 for a while, then try 3/6 again in a month or two...
Old Jun 3, 2003 | 10:49 AM
  #49
maxNYC's Avatar
I cruise on my maxspeeds with the 2/4 setting. I'll give 3/6 a whirl this evening. Unfortunately im using 15's on my 95 gle. I'm looking for a wheel upgrade. do most of you use 17'S?
Old Jun 3, 2003 | 10:59 AM
  #50
Jr'sMaxima's Avatar
Ill try 3/6 on my road trip this weekend and let you guys know about it when I get back. It'll be easy to change once I hit my destination, my grandpa's got a pit to pull back into, hehe.
Miket2006
Mar 1, 2021 03:55 AM
maxima-junky
Oct 7, 2015 06:13 PM
dvcamp
Sep 18, 2015 10:17 AM
