suspension sounds?
Old May 28, 2003 | 03:54 PM
kev926's Avatar
suspension sounds?
Hi I don't think I can search so I wanted to ask people before bringing my car in. I hear knocking sounds coming from the bottom front of my car at random times. Most of the time it's when I am braking to slow down at a light or when I go over bumps or potholes. Most of the time it's also when the car is going at less than 40 mph, but I don't know if it's just because I don't hear it when I am going faster.
What do you think (and what part) is making that noise? Oh, when it rains the sound doesn't show up as often. Help me out! Thanks..
Old May 28, 2003 | 04:12 PM
SlavDaddy's Avatar
Don't trust me, I'm sneaky
What else is going on?
What else is happening with your car? Did you just lower it? are your wheels turned when the noise happens? Does your car make noise if you just turn the wheel and your car is still?
Old May 28, 2003 | 04:21 PM
kev926's Avatar
Re: What else is going on?
My car is stock all around. It usually happens when I am going straight, but sometimes when I turn while the car is moving slow. When the car is still and I turn the wheel, the sound shows up sometimes but not all the time.
I told my friend to sit in the car and I pushed down on the front corners of the car, and she said she heard some sounds. I wasn't able to hear it myself from the outside so I am not sure if she meant the same sound I heard while driving.
Old May 28, 2003 | 07:05 PM
infinitiman96's Avatar
could be a strut bearing
Old May 29, 2003 | 06:03 AM
njmaxseltd's Avatar
Struts and / or strut bearings
Lower control arm bushings or ball joint
Sway bar end link bushings
Old May 29, 2003 | 06:29 AM
Axra's Avatar
I posted a thread about 1-2 weeks ago. I'm having the exact same issue. I haven't been able to figure it out yet, but I think my problem may have something to do with the cv-shaft.
Old May 29, 2003 | 06:32 AM
maxmobile's Avatar
I have the same noise, and suspect its the front sway bar and/or end link bushings. It just got louder this week and am looking for poly urethane bushings. Ill probably have it done by next week and will let you know if it works
Old May 29, 2003 | 07:47 AM
rc4max's Avatar
I have the same similarities. I'm definite the knocking is coming from my left front wheel. Either the cv boot, axle, or strut. I will also check the fstb. My dad said he had the same prob with his lexus and the mechanic to him that his *rotor* needs to be changed. He changed it and it does not make any more noise. I have a day off in about 2 wks and will check it out.
Old May 29, 2003 | 08:15 AM
Ceasars Chariot's Avatar
Old Maxima Legend
front mounts may need replacing ?
Old May 29, 2003 | 11:41 AM
95GreekMaxSE's Avatar
open your hood and while the car is on turn the steering whell back and forth. look at the bolt at the very top of the upper strut mount (where the FSTB goes). Does it move around.. it not supposed to..if so change your upper strut mount
Old May 29, 2003 | 02:02 PM
kev926's Avatar
THanks I will try doing that.
Do you guys know how much it would run approximately to fix something like this (given any of the scenarios mentioned above)?
I forgot to mention that the sound gets a lot more frequent and louder if I have a heavier load.
- kevin
Old May 29, 2003 | 02:16 PM
with labor a strut mount runs from 110 150
Old May 30, 2003 | 11:29 AM
kev926's Avatar
does anyone know how much these would cost each w/ labor?
Struts
thanks...!
Old May 30, 2003 | 03:03 PM
humberto_i30's Avatar
Entering the $uspen$ion Zone
Hi ! You are just entering the $uspen$ion Zone with your weird noises coming from the front end, my I30 was in the same situation months ago and I ended up paying about $2,000 dlls at the dealership to replace all the parts to eliminate the weird sounds.
Parts replaced were:
Struts
Strut Mounts
Strut Bearings
Outer tie rod ends
Alignment and Balancing
Now the weird sounds are gone, and the money from my checkbook too !
Good Luck !
Old Jun 1, 2003 | 07:16 PM
kev926's Avatar
Re: Entering the $uspen$ion Zone
You're kidding me! I am going to be so broke!
Will it be significantly cheaper if I don't get it fixed at Nissan but go to a regular mechanic (like some gas stations)?
Struts
Strut Mounts
Strut Bearings
Outer tie rod ends
Good Luck !
Old Jun 1, 2003 | 07:42 PM
You can take your car to any ASE Certified mechanic and expect same or better results as in the dealership, but I was having much trouble to get my Infiniti fixed, all the mechanics walked away just when they saw the infiniti logo in the front of my car, so my last option was the Dealership, they did a WONDERFUL work on my car, but GOOD WORK COSTS A LOT my friend !
Old Jun 1, 2003 | 07:49 PM
thisasian's Avatar
You mean the stealership fixed it for you
Old Jun 1, 2003 | 07:54 PM
Yes thisasian the STEALERSHIP fixed if for me, but actually I don't have time to keep visiting one mechanic a day, so the stealership did the work in my car, but at least they did a GREAT JOB on it for sure !
Old Jun 1, 2003 | 07:58 PM
thisasian's Avatar
Hehe, sorry... true, you get what you pay for. You won't have to worry about them doing quality work.
Old Jun 1, 2003 | 08:17 PM
One good thing (at least there's one) at the stealership is that the labor and parts carry a 12,000 miles/12 months warranty wichever comes first, so I'll be not worried next 12 months about my front suspension.
Old Jun 1, 2003 | 10:47 PM
kev926's Avatar
I used to go to this AAA certified shop but I still feel like I get ripped off. Last time to change my knock and oxygen sensor they charged me a total of 1100 bucks including labor. Afterwards, I started feeling that they try to charge as much as they can. The work they do is good, but I am not sure they are honest with their labor charges.
Old Jun 1, 2003 | 11:47 PM
polishpunk68's Avatar
my g/f's 96 gle does something similar. It is more of a ticking noise when the wheels are turned at extremely low speeds or stopped. Doesn't happen any other time.
Is it the same thing? I can do the labor myself and I know its not the struts. Is it the mounts?
Mahmuth
Aug 16, 2024 08:23 PM
user 11122324
42
Jul 18, 2022 03:35 PM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
