Help me diagnose this manual tranny noise...
Help me diagnose this manual tranny noise... (long, lots of detailed symptoms)
For the last two winters I've heard this strange sound from the tranny. It used to be;
- The sound is best described as... Well... It's not a whining, or a clicking. It's more like a very soft, muffled clacking sound. Just like there are two gears that still have lubrication but are not adjusted tight enough, os there's just a tiny bit of play and you can hear the gears clacking, but the lubrication is muffling the noise.
- Sound would be loudest when in 1st or 2nd (couldn't tell 3rd or higher because the wind noise was too loud)
- Sound would happen under acceleration or under engine braking.
- Sound would go away when the clutch was pushed in.
- There is no major oil leak from the tranny, but there is a 'damp' patch around the backup sensor.
- When I first noticed the sounds I had the tranny level checked at each oil change. Always reported as good.
- The sound has come back and is happening all the time now.
- The sound appears to be coming from the area of the driver's side axle or clutch area.
- Clutch engagement/disengagement and shifter feel is always normal.
These may, or may not, be related... When I sit with the engine idling and the stick in neutral, hood open, the sound happens when I release the clutch and disappears when I push the clutch in. With the hood and driver's window open it's really obvious - the transmission makes almost as much noise as the engine!
Could one you you guys with a stickshift do that same test and tell me if you can hear any noise from your tranny under the same circumstances? It's REALLY obvious as you push the clutch in - the amound of noise coming from the engine bay is reduced by half in my car.
The other "possibly related" thing is that if I accelerate very fast from a stop turning hard right, there is a strange noise/feel through the tranny/shifter that is not present when do the same thing turning left. I alway notice it as I pull out of our little sidestreet onto the busy 55mph two-lane highway - I have to get up to speed really fast. Dop you guys notice the same thing, or is that just me? I suspect my driver's side driveaxle as being near the end of it's useful life, which would account for this effect.
I'm thinking it's probably either the clutch components (throw-out-bearing) or input shaft bearings. You guys agree?
Time to look for an I30 tranny with an LSD...
Do a rebuild and swap them over one weekend...
I'm having the same problem, so here's a BUMP!
I have about 20k on a new ACT clutch, but the *** of a mechanic who put it in did a ****ty job and now claims it was a defective part. (When will I learn not to trust people with my car!?!?!)
I figured it was the clutch. As far as I can figure it, he didn't follow the correct torque sequence when tightening the pressure plate, bent the hell out of the fingers and it's been chatty since.
I guess I learned my lesson... If you wan't something done right, do it yourself.
tarun900
19
Dec 20, 2021 06:57 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
