To all with KYB dustboots...
Old Jun 2, 2003 | 07:03 PM
Vyrus's Avatar
Is there something wrong with the picture below? I believe an OEM bumpstop is sitting ontop of the KYB dustboot/bumpstop, should that be there? A buddy of mine at Merchant's put these on and I'm not sure if the that is an OEM bumpstop and if it should be left there (would it limit travel any since it's above the notch in the shaft)?
Thanks,
-Cyrus
Old Jun 2, 2003 | 07:39 PM
mzmtg's Avatar
Minister of Silly Walks
The KYB boots have bumstops built in. You have severly limited suspension travelw ith that setup. Remove the OEM stops.
Old Jun 2, 2003 | 07:41 PM
Vyrus's Avatar
I was hoping that since they were above the notch in the AGX shaft it wouldnt matter but I guess it does. Do ya think I could cut those puppies off?
Thanks,
-Cyrus
Old Jun 3, 2003 | 06:54 AM
njmaxseltd's Avatar
Thanks,
-Cyrus
Yes, you can just cut them with a sharp razor. Your ride will change once you fix that mess up.
BkGreen97
Apr 2, 2016 05:47 AM
Maxima_Joe
Nov 25, 2015 08:19 AM
maxima-junky
Oct 7, 2015 06:13 PM
dvcamp
Sep 18, 2015 10:17 AM
