Rear Sway Bar Noise!
I know this topic has been covered but I need advice. I can't get the popping noise to go away. It's mainley during slow turns or on driveways/small bumps.
I installed myself and triple checked and everything looks fine. I've re-tighned ect. What am I over looking here. It seems to come and go, but the last 2 weeks it's been here to stay!
I have a Stillen RSB by the way.
Thanks in advace.
Thanks in advace.
Re: Rear Sway Bar Noise!
Thanks in advace.
Thanks in advace.
Re: Re: Rear Sway Bar Noise!
How loud is your popping noise. Mine is now louder and more frequent. When I was backing out of the driveway at my parents house my dad told me he heard it from the backyard! It's anying in the car, but embaressing when everyone around you can hear it too.
Originally posted by drewm
I've got the stillen also, the popping is normal. I'm pretty sure it's due to the holes in the crossbar being slightly bigger than the screws, and the bar shifting and rubbing against the clamps.
Thats nice to know...wanna trade? J/k...at least yours is quiet. I think it is somehthing else since a lot of people have the Stillen RSB and haven't been complaining.
Originally posted by happyricefob
progress rsb doesn't do tat
My popping is about the same volume. Generally I only get the popping when I have people in my backseat or lots of stuff in my trunk, or when I angle a really steep driveway.
The Stillen sway bar clamps hit the floor boards if there to far back on the trailing arms. Personally I think the design of the sway bar is at fault. This is very common on a lowered car.
Originally posted by 96BLUMAX
Mine squeaks. Its an Addco.
i still don't get why people get stillen when it's so much more expensive than progress, and it's not doin its job. :confussed:
Originally posted by 96_vqmax
Yeah addco's braket is too long.I had to grind mine down a little,so that it will clear the lateral link.You don't have to if you don't want.But you will have to make sure it's not too close to the lateral link,so they are not rubbing each other.
How in the world did you install it?
That bar fit's perfect and mine hasn't made a sound in 3 years.
The Stillen mounts are junk. Have you ever seen a piece of suspension equipment not mounted with some kind of bushing or bearing? The Stillen bar is a crude hard metal to metal mount. It looks like an Erector set.
It's only expected to make noise if it's got to move at all. It's a poor design and they get a fortune for it too.
For what it's worth, I've had the Stillen RSB for more than 3 years and I've never touched it since the day I put it on. It has never made any noise and greatly improved the way my car handled and felt, almost like a different car. I positioned it directly under the beam, maybe that has something to do with it? Try giving them a call, they may be able to suggest something. My car is not lowered either, bad idea in NYC.
I've had an addco for 9 months now and only occasionally hear little pops from back there. But it's only ever when I'm _really_ going at it around a turn, and I'm not 100% sure it's the sway bar. I figure as hard as I'm turning, I'd probably hear some sort of noise even w/o the sway bar. Everyday driving, it's quiet. FWIW, I had no fit problems with the Addco bar. Easy as pie to install, didn't even jack the car up (I'm not lowered).
GMT
GMT
Not sure what the difference between the two products is. Looking at custommaxima.com, they say the progress one is better than the one they used to offer (the addco). Can't say I really see much difference in the picture, though the mounting hardware looks maybe a little better on the Progress. (There have been some quality control issues with the Addco - the first set of bolts I got had one with messed up threads on it - but they are quick to send you replacement parts if you need it.) The Addco bar is 7/8" thick, maybe someone with a Progress can say how thick it is. I'm not sure where you can get the Addco any more, it seems to have been pretty thoroughly replaced by the Progress.
GMT
GMT
Popping Noise from rear of vehicle
I have two Max both of which are 97's. I too had the same problem, except I was able to fix the problem by taking it to a trusted mechanic. He spent three hours looking for something loose to no avail, then finally resorted to tightening all of the suspension parts with his impact wrench. He wasn't able to tell me exactly which suspension bolt fixed the problem but he eliminated the "Crickets". Now the problem has reared its ugly head on my other car...I guess it's time for another trip to the shop!!! Hope this helps...The problem can be resolved, don't live with the noise!!!!
lowpost99
Oct 26, 2025 06:53 PM
Justin Kroll
Sep 2, 2015 11:06 AM
Maybe it's not center to the beam.
