lower ball joints
Old Jun 3, 2003 | 12:22 PM
jdworld's Avatar
lower ball joints
I went to dealer today for oil change,
and they told me that the lower ball joints needs
to be changed for about 590$!!!!!!!!
What is it? do you think I should have them replaced? How long can I keep it unchanged?
Is this price ok or should I shop around?
My car drives fine right now, I didn't notice anything bad about the car. It has a lot of milage though, 96 maxima with 145000miles.
Thanks a lot for your help.....590$$$$$$$...
Old Jun 3, 2003 | 04:33 PM
95_SE_5spd's Avatar
i think the best way i can put it, is if you like your wheels it's a good idea to get them replaced. if they are bad you will be able to rock the tire up and down while that wheel is in the air, it's an important joint seeing as though when they wear out they can ruin your tires, and i'm not too sure how likely it is, but one could break if it's worn out enough causing you wheel to fly out from under itself...which is probably alot more expensive....but 590 seems quite steep...if you know a mechanic personally you should see if they have a removal tool, that way you can do it yourself, or have him do it for cheaper...if not...then i guess it's up to you
Old Jun 3, 2003 | 07:03 PM
njmaxseltd's Avatar
Can you do lower ball joints without replacing the latteral link?
If new lower control arms come with the ball joint already pressed in them, you can probably save some money and buy a whole new assembly and install them yourself.
Then have the car aligned and you're all set for another 150,000 miles.
Old Jun 4, 2003 | 12:38 PM
jdworld's Avatar
thanks
Thanks for your help, guys.
I asked several local repair stores, and I got the estimate about 350$ to replace the joints and do the alignment.
Is this a difficult job to do? do you think if I can trust a local store to do it for me instead of nissan dealers?
Old Jun 4, 2003 | 03:13 PM
athlon omega's Avatar
Were you experienceing any vibration at high speeds prior to the discovery of the bad ball joints?
Old Jun 4, 2003 | 06:43 PM
95_SE_5spd's Avatar
ball joints are a fairly easy job given the right tools, so i think the local shop would be a good bet, especially if you're going to be paying that much less. just my 2 cents.
Later,
J
Old Jun 4, 2003 | 06:57 PM
klymkow's Avatar
The ball joints for the 4th gen Max come WITH the lower control arm. They are about $143 for the SE & GXE and about $168 for the GLE from www.nissanparts.cc
On the 3rd gen Max you can replace just the ball joint. Can't understand why they would go this way for the 4th gen Max.
Tim
Old Jun 4, 2003 | 08:07 PM
boybilly's Avatar
Had this problem a couple of weeks ago. You can buy just the ball joint. I took the control arm off...more easily than I expected.. and had the ball joint pressed in by a local shop (Canadian Tire). It's quite a bit cheaper that way and more fun!!
Old Jun 23, 2003 | 11:21 AM
FLO_BOY's Avatar
anyone know the difference between the SE and the GLE part?
is one better than the other?
anyone know how difficult the install is?
I'd look in my Chilton's, but I lost it
FLO_BOY
Old Jun 23, 2003 | 10:18 PM
FLO_BOY's Avatar
FLO_BOY
BUMP
FLO_BOY
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
MaxLvr21
Oct 17, 2015 12:11 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
