Sunroof LEAKING...Can anyone tell me how to fix it?
Old Jun 4, 2003 | 04:59 PM
1Phat Max's Avatar
Hi guys, my sunroof is leaking and the water comes down from liner on the sides and floods the floor..How can i fix it so it closes very tight where it leaves no space for water to go in. BTW its a 95 maxima GLE. thanx in advance..
Old Jun 4, 2003 | 07:07 PM
infinitiman96's Avatar
Make sure all the rubber is secure around the sunroof, if its not put some rtv silicone on it to seal it up.
Old Jun 4, 2003 | 07:08 PM
1Phat Max's Avatar
Would i be able to open sunroof after using silicon to seal it up?
Old Jun 4, 2003 | 07:27 PM
klymkow's Avatar
Re: Sunroof LEAKING...Can anyone tell me how to fix it?
The sunroof has drain hoses on both the rear left and right sides. There are tubes that run from the sunroof frame down the rear pillars behind the rear wheel wells and out the bottom of the car.
The right side hose connects into the drain fitting for the antenna.
You can probably try blowing some air up through the hoses or run a stiff wire up through them to clear them out. Some outside crud always gets in there (small leaves, tree seeds, etc)
Some amount of water will always seep through the rubber sunroof seal and into the frame. That's why the frame will always have the drain tubes at the rear corners.
Tim
bigdogsteve
Jan 31, 2018 04:18 PM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
jonreidhead
Jan 6, 2016 09:38 AM
leatherneck
Sep 30, 2015 09:16 PM
