Y pipe or exhaust first
Old Jun 6, 2003 | 04:47 AM
CityMax's Avatar
Dont know what to go with first a cattman Y pipe or a Greddy Sp. and where is the best place to go to get the best price.
Old Jun 6, 2003 | 04:58 AM
LiquidNine's Avatar
I would go with a Y first. Getting rid of those pre-cats is an important step to improved exhaust flow.
Old Jun 6, 2003 | 05:08 AM
Juki5536's Avatar
I think the first mod for your exhaust should be y-pipe, and if you want afterwards, do the Greddy. But definitely the y-pipe first.
Old Jun 6, 2003 | 05:37 AM
happyricefob's Avatar
V^___^V
get budget y-pipe first, $160 shipped.
Old Jun 6, 2003 | 05:38 AM
Smithdogg1's Avatar
Get the Y-pipe first, but why not just get a Budget Y-pipe for $180 shipped instead of the Cattman pipe? They are both quality made and will give you the same HP gains. And the cheapest price i have seen for the Greddy SP catback is $485 at www.adventon.com
Old Jun 6, 2003 | 07:36 AM
SleepyMaxxx68's Avatar
Y-PIPE no quetsion about it! You're stock muffler might make a lil bit of noise but oh-well......take the Cat off to....LoL....I did
Old Jun 6, 2003 | 08:07 AM
icheban26's Avatar
newbie question....wat exactly is a Ypipe???
tia.
Old Jun 6, 2003 | 08:49 AM
tia.
The best bang for the buck......
Old Jun 6, 2003 | 09:24 AM
icheban26's Avatar
haha...i'll keep that in mind. but wat is the actual funtionality of the Y-pipe. from the little research that i've done...i think it helps the car "breath smoother"(lack of a better technical term)...am i correct??? so is y-pipe a exhaust???
tia
icheban26(newbie)
Old Jun 6, 2003 | 09:29 AM
bb0ys's Avatar
the y-pipe is part of the exhaust system. It has two inlets that meet at a "Y" connection and form one outlet pipe that connects to the catalytic convert. The furthest reaching inlet connects to the front bank of cylinder's exhaust manifold and removes exhaust. The middle inlet (closer to the outlet of pipe) connects to the rear exhaust manifold and removes exhaust from there. An aftermarket y-pipe is a straighter tube than the stock pipe and doesn't have pre-catalytic converts.
Old Jun 6, 2003 | 09:30 AM
PLus it's a lot lighter and has a larger diameter
Old Jun 6, 2003 | 09:32 AM
LiquidNine's Avatar
tia.
It is the part of your exhaust that goes from your engine's exhaust manifolds back to your Cat. In the stock Y, there are pre-cats which help clean up emmissions before the main cat is hot enough to work. The pre-cats are quite restrictive and the stock pipe has bad flow characteristics to say the least. An aftermarket Y has no pre-cats, it's just nice smooth pipe with mandrel bends, preferably. Budget Exhaust makes a quality pipe for a great price which is why many members of the .org reccomend them, but there are always different opinions on which manufacturer is the best.
http://www.budgetexhaust.com
check out their 'custom parts' to see the Y (they call it an F pipe though) and keep in mind all prices are in canadian dollars.
Old Jun 6, 2003 | 09:46 AM
icheban26's Avatar
now i know. thanks bb0ys, SleepyMaxxx68, LiquidNine for educating a newbie. i will def look more into changin my Y/F pipe as soon as i get my suspension replaced.
thanks
icheban26
Old Jun 6, 2003 | 10:29 AM
sblax2000's Avatar
Does any Max owner in California have a Y-Pipe? I heard you can't pass emmissions here with one, is that correct? I would like to get one, but would also like to pass emissions.
Old Jun 6, 2003 | 02:53 PM
drewm's Avatar
For all the questions about y-pipes, exhausts, everything airflow:
http://drewm.dyndns.org/~drew/maxfaq...imaPerformance
Old Jun 6, 2003 | 03:11 PM
sblax2000's Avatar
When passing emissions testing, are you allowed to warm your car up before hand in order to pass emissions? Are y-pipes reversible or do they need to be welded on?
Old Jun 6, 2003 | 03:32 PM
StygianMax's Avatar
thanks
icheban26
Here's more reading for ya! The pics and text are great. There are dyno plots showing the difference in performance between oem y-pipe and aftermarket pipe (Budget Exhaust's in this case).
Old Jun 6, 2003 | 06:12 PM
pjalst
How many O2 sensors attatch to the Y pipe, and what is it called( i want to replace mine when I install a Y pipe
Old Jun 6, 2003 | 07:42 PM
LiquidNine's Avatar
There are 2 O2 sensors in the non-cali spec Ypipe (unsure about the cali cars)... if you crawl under your car you will see them screwed in perpendicular to the vertical section, one for each down-pipe.
Old Jun 7, 2003 | 07:27 PM
pjalst
thank you, are these called the upward O2 sensors and are they the same part number?
Old Jun 7, 2003 | 07:35 PM
95GreekMaxSE's Avatar
does anyone notice more frequent damage to the O2 Sensore becuse of the biigger flow and does the cat at all get more prone to damage???
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
Justin Kroll
Oct 1, 2015 07:03 PM
Socalstillen
Sep 26, 2015 12:01 PM
