Is it ok to start engine w/o anything connect to throttle body?
Old Jun 6, 2003 | 02:05 PM
Larcenist's Avatar
I currently don't have anything connected to my throttle body. What I mean by this is that my MAF, airbox, filter, and any other pipe and air scoope is not connected. So there isn't anything connected on the right side of my throttle body. Is it safe to start my engine without anything connected to the throttle body? Will it cause any damage to my vehicle. All I want to do is release my fuel pressure so that I can replace my fuel filter. So it just needs to be on for like 5 sec and then turned off and turned on again maybe 2 more times for 5 sec each until my car stalls.
Old Jun 6, 2003 | 02:18 PM
Chunger's Avatar
My other car is a Hybrid
You need up to the MAF (with connection)...
Old Jun 6, 2003 | 02:19 PM
plurco's Avatar
it is not good since you have no filter in place. Plus if it starts it will run like crap. it only takes a few secs to reconnect the air box, MAF, and midpipe as one peice.
Old Jun 6, 2003 | 03:01 PM
drewm's Avatar
Re: Is it ok to start engine w/o anything connect to throttle body?
You'll trigger a CEL, which you will need to reset. Put it all back on, it only takes a second.
Old Jun 6, 2003 | 04:01 PM
ThurgoodJenkins's Avatar
You don't need to do any of that. Just open the gas cap to unpressurize and get to work. A little fuel will come out but it's no big deal. And running the engine w/o the maf won't hurt it, you'll just run pig rich.
Old Jun 6, 2003 | 09:06 PM
maxmobile's Avatar
You can also remove the fuse next to the steering column for the feul pump and start the car untill it stalls, that should release pressure so you can install the feul filter
http://www.maximadriver.com/modules....=article&sid=8
Old Jun 6, 2003 | 09:49 PM
Ramius83
Even if you do crank it with just the intake piping disconnected, it will idle for about 10 seconds and then shut off completely.
Old Jun 7, 2003 | 11:01 AM
Larcenist's Avatar
Thanks for all the replies. I guess I'll just reconnect everything before starting the car.
vingodine
45
May 21, 2016 12:46 PM
homewrecker
Aug 24, 2015 08:56 PM
maxinout93
Aug 20, 2015 02:17 AM
Samedi
Aug 13, 2015 04:05 PM
