help with PU bushing on control arm
Old Jun 6, 2003 | 09:06 PM
zntema's Avatar
hello
I am in the middle of changing the bushings on my control arm and i was wondering if u remove the metal ring around the cylinder to make the pu bushings fit?
thanks
Old Jun 7, 2003 | 07:05 AM
n2oMike's Avatar
The smaller front bushing will have a metal sleeve on it's outside. When pressed out, the metal sleeve wil generally stay, while the rubber gets ripped out. You will need to grind a slot along it's length to relieve its tension... and allow it to come out. You can use a small grinder, or carefully use a sawzall or hack saw.
Good Luck!
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
