How to fix a dent ona door
Old Jun 7, 2003 | 09:56 PM
95BLKMAX's Avatar
I just bought my black 95 maxima SE 2 weeks ago, and yes this IS my 1st post. With the previous owner, some1 had backed up into the rear driver side door. The dent is about 6 inches across and the paint is not chipped. I got 2 questions. First, should I bang it out from the inside w/ a rubber mallet, or use a suction cup and pop it back into place? Second, IF I use the suction cup , the trim piece on the door is in the middle of the dent, so I don't know if the suction cup will b able to create a strong enough vacuum to pull out the dent?
Old Jun 7, 2003 | 10:48 PM
iansw's Avatar
Try the Ding King....That late night TV product that WIllie Mayes sells.
Some people on here have actually had good luck with it, as I recall.
Old Jun 8, 2003 | 12:36 AM
image's Avatar
letme know how u fix it.. I got a indention in my car about 2 inches prbly from a jacked up truck and someone getting out.. I heard of the paintless dent removal.. but if i can di it myself that would be great.. letme know what happens.. soemone told me takping a bag of dryice to your dent.. but i think that would do more harm that good.. dryice= cold= get stuck on your car and rip the paint off.. someone prove me wrong..
Old Jun 8, 2003 | 02:22 AM
Ookami's Avatar
I've read Ding King is crap (FHM magazine
As image said... "paintless dent removal" ... most body shops
do this. Just ask for an estimate, it should be $60/dent but
it really depends. I had PDR done for my hail damage... after
I got it back I felt better / cared more about my car.
I'm actually having damage fixed soon... (not PDR) ... scraped
my right rear quarter up trying to avoid hail next
time I'm just taking hail damage. (no hail damage actually
occurred this time)
Old Jun 8, 2003 | 05:38 AM
95BLKMAX's Avatar
I'm going to get this done at my friend's house on Monday afternoon, I'll let you know how it comes out. Thanks for the help
Old Jun 8, 2003 | 08:56 AM
image's Avatar
i have a few gashes in my door.. and some small ones... When i get some extra money laying arround ima go get it fixed.
Old Jun 8, 2003 | 09:49 AM
nadir_s's Avatar
vicodin ... gift of life
lololol
my door got backed into... i need to get the entire outside skin of my driver side door replaced. Actually the shop I took it into is replacing the entire driver door shell.
Hopefully your's is just popped in...
Old Jun 8, 2003 | 09:54 AM
gabex's Avatar
Lemme know if the Ding King works..I had a basketball size dent on my passenger quarter pannel and I used a suction cup to pull about half of it out. There is a little bit left to pull that I couldn't get.
Old Jun 8, 2003 | 10:02 AM
nadir_s's Avatar
if u guys do want to use ding king, i believe walmart sells em for $20.
Old Jun 8, 2003 | 12:05 PM
bb0ys's Avatar
I've used the ding king. It works if the dent is not a crease in the metal.
Old Jun 8, 2003 | 12:11 PM
ilumo's Avatar
I actually had good luck with Ding king. I was stupid and tried to see how much pressure was needed to be exerted to activate the alarm on my car. and so I tried to use my hip and push up against the car a few times... The end result... The alarm didnt go off, but I was left with a double quarter sized dent... Thank god for ding king... so now 99.9% of the ding is gone, and can only been seen if you knew it was there before. So if the dent isn't TOO large, sing king would work.
Old Jun 8, 2003 | 05:37 PM
MaxWilk's Avatar
You said that the molding was right in the middle of the dent. That means that a suction cup might not work. A shop like a Maaco will probably charge around $200-300 depending on the size of the dent. They will also might have to replace the molding. You have to watch places like that, though. They are mostly independently owned and each place puts out different quality. A good shop will charge quite a bit more, but do a better job. Here in NC we have a place called Dent Wizzard that does the suction professionally. maybe start with a place like that, if your suction repair doesn't work.
Junebug1701
Sep 25, 2015 01:54 PM
JoshG
51
Sep 21, 2015 10:41 PM
lkiller123
Sep 21, 2015 03:00 AM
ajahearn
Sep 19, 2015 03:03 PM
