Horrible Gas Mileage
Old Jun 9, 2003 | 09:15 AM
99maxGTR's Avatar
my car has been stock for a while until i put in a custom intake..just a HKS type filter with adapter..and replaced my steelies with SE rims..well ever since then my mileage has been horrible..i used to fill up my gas every 1.5/2 weeks now it's every week...ne suggestion with what the problem is. i don't really drive too harsh so i don't think it's that and i know intake doesn't kill gas that bad right?
Old Jun 9, 2003 | 09:17 AM
Socrates's Avatar
Re: Horrible Gas Mileage
What constitues horrible? How many miles are you getting?
Old Jun 9, 2003 | 09:19 AM
97blackSE's Avatar
you could possibly have a bad upstream O2 sensor, clogged fuel filter, any number of things...either that or the SE wheels weigh a LOT more
Old Jun 9, 2003 | 09:20 AM
95GreekMaxSE's Avatar
is your new intake leaking at all. Check for vacume leaks. Fuel mite be losing 02 casue leaks causing it to run richer than normal. Did you by a new adapter or made your own???
Old Jun 9, 2003 | 09:25 AM
99maxGTR's Avatar
i bought the adapter but it was mad for the 4th gen max..i get around like 15mpg?? for a full tank i go about 250miles...no it's not leaking..
Bmr4life's Avatar
what is considered good gas milage for these cars? With my max it has ranged from 22 to 29 mpg. 22 was when i was doing 110 on te freeway and a lot of city driving and the 29mpg was for 400 miles at 80mph.
Old Jun 9, 2003 | 10:39 AM
jerzeeMax's Avatar
Good gas mileage for 4th gen is 24 mpg. IIRC this is what the manufacturer rating is. When I had dead/dying 02 sensors I was only getting barely 20mpg. After I swapped my upstream sensor I'm getting a solid 24 mpg mix local/highway, pretty much no matter how I drive. This is with all the regular bolt ons (intake, y, exhaust) before and after. These results come from tank milage/gallons filled at the pump.
Old Jun 9, 2003 | 11:29 AM
JsL's Avatar
JsL
Is 24 freeway driving. I have mostly freeway driving and a little city driving and a barely get 20mpg
Old Jun 9, 2003 | 12:34 PM
LiquidNine's Avatar
What pressure do you have your tires at currently since the new wheels? Lower pressure could affect your MPG.
Old Jun 9, 2003 | 01:00 PM
genepool's Avatar
I recently got 22MPG with 75% highway and granny style driving (not revving over 2500). I recently replaced plugs and fuel filter... Do you always have to drive like this to get good gas mileage?
Old Jun 10, 2003 | 08:51 AM
99maxGTR's Avatar
i think i need a new o2 sensor from what im hearing right? and i think my tires need to be replaced..my car seemed alot heavier after i put on the SE rims...
Old Jun 10, 2003 | 08:57 AM
happyricefob's Avatar
V^___^V
intake suppose to help ur milage
Old Jun 10, 2003 | 12:40 PM
MaximaSE96's Avatar
Maxima Owner
check ur plugs
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
