right rear o2 sensor
I have a 99. Mine has 2 front and 1 rear. Bank 1 sensor 2 is what the rear is called. The rear was located right behind the Cat. Very easy to change if you get it loose quickly. Just jack the car up and get under the middle and you will see it screwed into the pipe w/cord and a wiring harness. Look up into the front sections for the other 2. If you are Cal spec, I don't know much about where yours are located.
Huttig2009
09-25-2015 03:31 PM
Maxilano
08-31-2015 07:33 PM
