Does your gas tank door stick out?
Old Jun 10, 2003 | 07:08 AM
Bluebird's Avatar
I am Roid Rage
When my gas tank door is closed, the front side of it (the side it hinges on) sticks out about 3/16" from the body. I never noticed it before and I'm worried that some gas station employee might have bent it out.
Anyway, does yours sit totally flush or does it stick out some?
Old Jun 10, 2003 | 07:14 AM
BlackSE5spd's Avatar
ooh...sorry to hear that...mine is flush with the car which leads me to believe that you are correct about it having been bent at some point.
Old Jun 10, 2003 | 07:21 AM
Bluebird's Avatar
I am Roid Rage
It was probably the pump monkey at the Kwik Fill.
Old Jun 10, 2003 | 07:35 AM
LiquidNine's Avatar
Mine is flush also. I hope the fix is easy for ya.
Old Jun 10, 2003 | 08:01 AM
That is the reason that I never let anyone fill my tank but me, that and they always seem to lose your gas cap...I mean, what's the deal with that?
Old Jun 10, 2003 | 08:05 AM
Bluebird's Avatar
I am Roid Rage
I've stopped letting mechanics work on my car because they always seem to screw it up. Now I can't even let somebody pump my gas. I mean, how do you screw up pumping gas?
Old Jun 10, 2003 | 08:50 AM
maxfanfromohio's Avatar
Shiver me timbers.
Mine is bent also Kris. The door doesn't shut at all anymore(ghetto). I ordered a used one off of Sal here on the org. Once it is bent it is hard as hell to get it to bend back the way it is supposed to go. Good luck.
Old Jun 10, 2003 | 09:11 AM
Bluebird's Avatar
I am Roid Rage
Thanks Fred.
Wonder if I can have it fixed under warranty
Old Jun 10, 2003 | 11:21 AM
Bmr4life's Avatar
yeah, mines bent to. One day my mom was pumping gas and trying to close hte door and it wouldn't close at all. Not really sure what happened. I doubt its had to fix though, its real easy to bend metal and after playing with it for a couple of minute I can get it to close but the level/switch is off so i just push the front part and it pops open, still sticks out like your though but its a lot better than being open all the time.
Old Jun 10, 2003 | 11:32 AM
95emeraldgxe's Avatar
mine was flush, maybe you can order the piece from the dealer, or better yet courtessy
Old Jun 10, 2003 | 11:52 AM
Bmr4life's Avatar
ok, just got back from outside, my job just had a fire drill so I used that time to work on my gas door. Bent it back as close as i could get it to how its supposed to be and it doesn't look all that bad. the level works now and the door doesn't stick out. Only thing is its not centered perfectly, but that doesn't bother me much.
So go try it, just use your weight and lean on the door with your hands, it worked for me.
Old Jun 10, 2003 | 01:02 PM
Bluebird's Avatar
I am Roid Rage
BMR4Life: Good to know that you did it with no problem. I'm just going to try and bend it back tonight.
Old Jun 10, 2003 | 03:42 PM
SleepyMaxxx68's Avatar
welcome to the club mine was bent to but my dad banged into place with a hammer whiule covering it with a towel no sctrachs but a lil ghetto I know but hey it's now flush
Old Jun 10, 2003 | 06:41 PM
KsuMax's Avatar
Cheesing away...
Mines flush.
Old Jun 11, 2003 | 07:31 AM
Bluebird's Avatar
I am Roid Rage
Put a towel over it and hip checked it a couple of times last night. All good to go now.
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
JoshG
51
Sep 21, 2015 10:41 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
