0701 Multiple Cylinder Misfire Code
I threw an engine light today and I got the code 0701 Multiple Cylinder Misfire. What should I look for, I have already replaced three Fuel Injectors, New fuel filter, Clean Throttle body. What should I look for? I noticed the exhaust was misfiring and stuttering. The misfiring/stuttering noise only happens every once and a while. My Maxima also idles rough and then other times it doesn't.
Also, I noticed that lately when I go to a stop and I push in the clutch the rpm will drop down below 500 and then come back up to about 650-700. Keep in mind I have just cleaned my throttle body. Any Ideas?
-1995 Nissan Maxima Se 5spd, brand new clutch anout 500 miles ago, budget y pipe and k&n air intkae. Please help me diagnose the problem.
Thank You,
-Nick
Thank You,
-Nick
I got an 0201 (Ignition Signal Circuit) soon followed by an 0603 (Cylinder #6 Misfire) and had a rough idle as well and it turned out to be a bad ignition coil. Idles and runs much smoother now.
I just got this same code yesterday.
I got that exact code yesterday.
I drive a 95 auto se. marron if it matters.
Ok my car got bad idle **** about 9 months now.
I replaced alot of sensors.ects/knocksensor/o2 sensors/And did a Full Intake Manifold removal cleaing/And of couse fuel filter twice.
Nothing Changed. Nothing.
As of Today. 6-10-03. My car now idles so low, and lopes that it just stalls if my foots off the gas for more than say 10 seconds.
It started with that 500/400 rpm rough idle. Now My car is crap.
I ALSO got this code 8Long/6short. EVAP canister purge valve selonid.
Now. wtf does that mean? I checked the haynes manual.
Ahhh, it describes all the symptoms but it could be anything.
I got an appointment with my mech. tommrow ill update ya.
its your ignition coil most likely, i had a bad one bud found out that the ahrness connector pins were bent. but yeah it makes the car drive like crap and i didnt liek my car anymore when that happened. but now i like my car again, so check ur ignition coil by doing this
;switch coils into diffrent holes and while engine is on disconnect harness and if the engine starts to fail than the coil is bad
rpm drop
may not be related, but I had this same type of rpm drop. Even lower like 200rpm, it stalled sometimes too. It was caused by not having the tube from my intake hooked up(the way it should be) to the valve cover. I had a K&N breather filter on the side of the valve cover instead.
It just sound similler, this would happen when I would push in the clutch when coming to a stop.
Good luck
Good luck
Re: rpm drop
Good luck
Good luck
Thank you,
-Nick
jmlee44
10-02-2022 02:13 PM
TKHanson
11-24-2018 01:39 AM
